Intel® C++ Compiler
7956 Discussions
Option for compiler to print out a candidate list?
jheyd
Hi everybody,
is there an option for the compiler to print out the function candidate list it uses to determine that there's no such overload for the thing you are trying to call? It only tells me it can't find a matching function, not what the candidates are... GCC does this and it's extremely useful...
Thanks a lot in advance,
JJ
jheyd
Thanks!
Today I actually got a candidate list when the overload was ambiguous. So something is there. It just doesn't print a candidate list of none of them match...
Milind_Kulkarni__Int
New Contributor II
Could you share the bits of code that gave the candidate list in compile error, as Iam not able to get how you are able to get..
leaving that, does it then satisfy your requirement.
jheyd
Here is an example of the ambiguous overload use case that will generate a candidate list:
[cpp]struct foo_t { foo_t ( int ){} };
struct bar_t { bar_t ( int ){} };
class FBTest {
    void func( foo_t ) {}
    void func( bar_t ) {}
int main( int, char ** ) {
    FBTest c_object;
    c_object.func( 5 );
    return 0;
[/cpp]
And the candidate list:
[plain]$ icpc ambiguous.cpp
ambiguous.cpp(15): error: more than one instance of overloaded function "FBTest::func" matches the argument list:
            function "FBTest::func(foo_t)"
            function "FBTest::func(bar_t)"
            argument types are: (int)
            object type is: FBTest
      c_object.func( 5 );
               ^[/plain]
That's a fine compiler error which could only be improved by showing the line numbers of the candidates.
Here, on the other hand, is an example .cpp that shows the lack of a candidate list if none of the overloads match:
[cpp]struct foo_t     { foo_t    (){} }; static const foo_t     foo;
struct bar_t     { bar_t    (){} }; static const bar_t     bar;
struct foo_bar_t { foo_bar_t(){} }; static const foo_bar_t foo_bar;
class FBTest {
    FBTest c_object;
    c_object.func( foo_bar );
    return 0;
[/cpp]
Here is what ICC prints out:
[plain]$ icpc candidates.cpp
candidates.cpp(16): error: no instance of overloaded function "FBTest::func" matches the argument list
            argument types are: (const foo_bar_t)
               ^[/plain]
This isn't very helpful... For comparison, GCC produces a candidate list for the same code:
[plain]$ g++ candidates.cpp
candidates.cpp: In function `int main(int, char**)':
candidates.cpp:16: error: no matching function for call to `FBTest::func(const foo_bar_t&)'
candidates.cpp:8: note: candidates are: void FBTest::func(foo_t)
candidates.cpp:9: note:                 void FBTest::func(bar_t)[/plain]
BTW, here's my ICC version string: "icpc (ICC) 11.1 20091130"
Om_S_Intel
I have submitted a feature request to Intel compiler development team. I willinform the forum users when there is update on this.
