Intel® C++ Compiler
7875 Discussions
Overriding data dependency and force vectorization
Aniruddha_P_
I have a loop which inside a parallel construct which goes like this
# pragma omp parallel ... //directives
// other loops
#pragma omp for
for (i=1; i<=nx; i++) for (j=1; j<=ny; j++) for (k=1; k<=nz; k++)
	  p_sparse_s = RLL + (riri_sparse2 / noemer_sparse) * p_sparse_s;
// other loops
On inspecting it seems this loop is not being vectorized because of assumed dependency. On further inspecting with dependence analysis there is no dependency ( as evident from the code ). How should the directive be changed so that I enforce vectorization.
Also I tried using ivdep directive still the compiler didn't vectorised.
Sravani_K_Intel
You can try other methods of enforcing vectorization listed here.
TimP
Black Belt
You don't show sufficient information to understand why there might be a dependency; it's not at all evident how you have declared p[][][].  The requirements for restrict qualifiers on your declaration of p[][][] get annoying with multiple levels of indirection, so I'm guessing you may not have that set up.  You could over-ride that category of dependency  if you write the nested loops out with #pragma omp simd on the inner loop.
