I'm newbie with Linux and I'm having trouble with compiling a make file which works well in a 32-bit machine. I didn't write this program but I need it to work to use its functionalities. My machine is 64-bit and I get the following message error:
cd pmtTools; make
make[1]: Entering directory `/home/daniel/Documents/Master_thesis/data_Daniel-Thomas/photondet/trace/PMTSignalsAnalysis/pmtTools'
g++ -shared -L/home/root/root/lib -lCore -lCint -lRIO -lNet -lHist -lGraf -lGraf3d -lGpad -lTree -lRint -lPostscript -lMatrix -lPhysics -lMathCore -lThread -pthread -lm -ldl -rdynamic -o libPmtTools.so hit.o event.o waveform.o readLeCroyBinary.o pmtToolsDict.o
/usr/bin/ld: hit.o: relocation R_X86_64_32S against `vtable for hit' can not be used when making a shared object; recompile with -fPIC
hit.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[1]: *** [libPmtTools.so] Error 1
make[1]: Leaving directory `/home/daniel/Documents/Master_thesis/data_Daniel-Thomas/photondet/trace/PMTSignalsAnalysis/pmtTools'
make: *** [all] Error 2
I've been trying to solve the problem by using this website but I don't get the program to work... http://www.gentoo.org/proj/en/base/amd64/howtos/index.xml?part=1&chap=3I'm not used to makefiles and that's why I don't manage to modify the makefiles properly to PIC compile the shared libraries. I added globally the flag 'export CXXFLAGS=$CXXFLAGS -fPIC' but it didn't work. I'm just completely lost.
Here are the make files (two make files and one which calls them).
CXX = $(shell $(ROOTCONFIG) --cxx)
LD = $(shell $(ROOTCONFIG) --ld)
CFLAGS = $(shell $(ROOTCONFIG) --cflags)
LIBS = $(shell $(ROOTCONFIG) --libs)
SOFLAGS = -shared
CINTSRCS = event.cc hit.cc
CINTINCS = event.h hit.h
OBJS = hit.o event.o waveform.o readLeCroyBinary.o pmtToolsDict.o
LIBPMTTOOLS = libPmtTools.so
all: $(LIBPMTTOOLS)
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:~/Documents/Master_thesis/data_Daniel-Thomas/photondet/trace/PMTSignalsAnalysis/pmtTools
$(LIBPMTTOOLS): $(OBJS)
$(LD) $(SOFLAGS) $(LIBS) -o $@ $(OBJS)
%.o: %.cc
$(CXX) $(CFLAGS) -c -o $@ $<
pmtToolsDict.cc: $(CINTSRCS) $(CINTINCS) pmtToolsLinkDef.h
@echo "Generating dictionary pmtToolsDict..."
$(ROOTCINT) -f pmtToolsDict.cc -c -p $(CINTINCS) pmtToolsLinkDef.h
clean:
rm -f pmtToolsDict.cc pmtToolsDict.h $(LIBPMTTOOLS) $(OBJS)
dox:
rm -rf html
$(DOXYGEN) pmtTools.dox
------------------------------------------2---------------------------------------------
ROOTCONFIG = $(ROOTSYS)/bin/root-config
CFLAGS = $(shell $(ROOTCONFIG) --cflags) -I../pmtTools
LIBS = $(shell $(ROOTCONFIG) --libs)# -L../pmtTools -lpmtTools
OBJS = analysis.o
SHARED = ../pmtTools/libPmtTools.so
EXE = analysis.exe
all: $(EXE)
$(EXE): $(OBJS) $(SHARED)
$(LD) $(LIBS) -o $@ $(OBJS) $(SHARED)
$(SHARED):
cd ../pmtTools; make
%.o: %.cxx
test: test.cxx $(SHARED)
$(CXX) $(CFLAGS) -c -o test.o test.cxx
$(LD) $(LIBS) -o test.exe test.o $(SHARED)
clean:
rm -f $(EXE) $(OBJS) test.o test.exe
-----------------------------------------3---------------------
all:
cd pmtTools; make
cd analysis; make
clean:
cd pmtTools; make clean
cd analysis; make clean
Hope that someone can help me. Thanks in advance!! Daniel
