It appears that I need:
#undef __PURE_SYS_C99_HEADERS__
#define __PURE_INTEL_C99_HEADERS__
to cause the Intel headers to NOT include any of the gcc headers
on a Linux system. I need this as the gcc headers have bugs.
Do any of the icc command line options cause the gcc headers
to be skipped? Or, do I need to do the above C preprocessor
statements in my code?
Hi tydeman,
Does -nostdinc fulfill your needs?
-nostdinc
Do not search the standard system directories for header files. Only the directories you have specified with -I options (and the directory of the current file, if appropriate) are searched.
Feilong
I believe not. I think that would disable both the gcc headers and the intel headers.
That's true. How about -isystem option? It adds directory to the start of the system include path.
icc -c -nostdinc -isystem /opt/intel/Compiler/11.1/072/include a.c
Feilong
Feilong
That looks like it will work.
My #undef and #define and your changing the system headers appear to be about the same as a workaround of the gcc headers.
Topic Options
