Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
7597 Discussions
Parallel Image Processing in OpenMP - Image Blocks
Royi
I'm doing my first steps in the OpenMP world.
I have an image I want to apply a filter on.
Since the image is large I wanted to break it into non overlapping parts and apply the filter on each independently in parallel.
Namely, I'm creating 4 images I want to have different threads.
I'm using Intel IPP for the handling of the images and the function to apply on each sub image.
I described the code here:
http://stackoverflow.com/questions/29319226/parallel-image-processing-in-openmp-splitting-image
The problem is I tried both sections and parallel for and got only 20% improvement.
What am I doing wrong?
How can I tell each "Worker" that though data is taken from the same array, it is safe to read (Data won't change) and write (Each worker has exclusive approach to its part of the result image).
Thank You.
jimdempseyatthecove
Black Belt
You may want to partition your image differently than in quadrants. The reason being is your processor is capable of processing the data using SSE/AVX/AVX2/... On a 4-way partition, using quadrants results in the vectored operations running half the distance before having to loop. If your data is organized such that it runs row by row, then divide the number of rows by the number of workers.
#pragma omp parallel for
for(int iRow = 0; iRow < height; ++iRow) { // or += height / chunk
  iPos = iRow * width;
Also, look at your pKernel to assure that it is vector friendly.
Jim Dempsey
