Intel® C++ Compiler
7782 Discussions
Parallel Studio 2017 XE Update 4 and VS2017 Update 3
MHlav
I cannot get Parallel Studio 2017 XE Update 4 to integrate with VS2017 Update 3 (15.3.2).  The installer does not seem to recognize this update to VS2017 as the compiler is not listed in the integration list when I try to install it.  Earlier versions (e.g., 2015) appear, but not 2017.  Anyone else seeing this or know how to solve it?
Viet_H_Intel
Seems like we have a problem with VS2017 v15.3.2. but upgrading to 15.3.3 would fix it. Can you give it a try?
https://software.intel.com/en-us/articles/intel-software-development-tools-integration-to-vs2017-issue
Viet Hoang
roger567
I have a similar problem and am using 15.3.3.
Clearly I need an older build of something - where is the problem?
Should I use an older build of VS 2017 or of the Intel compiler (or both)?
