I had VS2015 integrated with XE2015 CPP, and on the last update, CPP updated followed by FORTRAN, and now I only see FORTRAN integrated with VS2105. How do I get CPP back?
-Steve
Hi Stephen,
Please re-install the latest update of IPS XE Composer Edition for C++ 2015. See if this fixes the problem.
Stephen, without the install log files (intel_*pset*.log and intel_*issa*.log under %TEMP%) it's hard to find out what's going on. To ensure CPP, you can launch the setup.exe from the original package and modify the configuration to add CPP/IDE back and it should work. The other option is like Feilong suggested to install the latest update of IPS as well which should work.
_Kittur
