Intel® C++ Compiler
7956 Discussions
Parallel Studio XE 2016 Composer Xcode OpenMP Integration
Matthew_Z_1
Hi there,
So I've installed Parallel Studio 2016 XE Composer and have it integrated with my XCode.  In fact I am able to change my project build settings to use ICC Intel C++ Compiler latest release, or even version 16.0.  However, when I try to use #include <omp.h> at the top of my file, the compiler does not recognize omp.h.  I also tried installing this: https://www.openmprtl.org/download#stable-releases which is supposedly coupled with the latest parallel studio on Mac.  However, it uses clang, and after installing cmake and using cmake to install the OpenMP in that link, it turns out omp.h is still not recognized no matter which of the three compilers I use, whether it be Apple's clang or the other two intel compilers.  I also searched my file system for omp.h and it turns out that it is located in /opt/intel/compilers_and_libraries_2016.1.111/mac/compiler/include/.  I manually added that path to my header search paths in XCode, but my program still cannot find omp.h.  I also tried including <libiomp/omp.h> and <libomp/omp.h> to no avail.  Any ideas on how I can get openmp to function properly?
P.S.
When I run intel software manager, it seems that if I go under the licenses tab, there are buttons to activate five things on a list: Integrated performance primitives, math kernel library, parallel studio XE 2016 composer edition for c++, and other things.  It says support expires on 11/6/16, and if I click the activate button, it will ask for my serial number, and if I enter it and then click the second activate button, it will tell me that the license file cannot be saved and to make sure I have permissions to Intel license folders.  Could this be an issue?
Thanks!
chinhster
foo.c:
#include <stdio.h>
int main(int argc, char *argv[])
        printf("Hello world!\n");
        return 0;
> icc --version
icc (ICC) 16.0.1 20151020
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
> icc -x c -arch x86_64 -mmacosx-version-min=10.7 -O3 -w1 -std=c99 -openmp -fvisibility=hidden -fp-model precise -fno-rtti -fno-inline -lncurses -multiply_defined warning -static-intel -openmp -framework Cocoa -lstdc++  foo.c   -o foo
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/dsymutil foo -o foo.dSYM
warning: (x86_64) /nfs/fx/proj/openmp/promo/20150922/tmp/mac_32e-rtl_5_nor_sta.rel.41.r1.c0.s0....h0-fxeomac08/libtbbmalloc/backend.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20150922/tmp/mac_32e-rtl_5_nor_sta.rel.41.r1.c0.s0....h0-fxeomac08/libtbbmalloc/backref.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20150922/tmp/mac_32e-rtl_5_nor_sta.rel.41.r1.c0.s0....h0-fxeomac08/libtbbmalloc/frontend.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20150922/tmp/mac_32e-rtl_5_nor_sta.rel.41.r1.c0.s0....h0-fxeomac08/libtbbmalloc/large_objects.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20150922/tmp/mac_32e-rtl_5_nor_sta.rel.41.r1.c0.s0....h0-fxeomac08/libtbbmalloc/tbbmalloc.o unable to open object file: No such file or directory
warning: no debug symbols in executable (-arch x86_64)
dsymutil is used to generate a bundle of debug symbols that I can use to convert crash logs to symbolized crash logs since my app is stripped when shipped.
chinhster
Here's the result from using icc 15.0.1:
> icc --version
icc (ICC) 15.0.1 20141022
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
> icc -x c -arch x86_64 -mmacosx-version-min=10.7 -O3 -w1 -std=c99 -openmp -fvisibility=hidden -fp-model precise -fno-rtti -fno-inline -lncurses -multiply_defined warning -openmp -framework Cocoa -lstdc++  foo.c   -o foo
I'm not concerned with the no debug symbols warning.
KitturGanesh
@chinhster: Thanks for the code snippet but couldn't reproduce on our systems. I've passed on the same to the product team to see if they can try to reproduce and if so I'll keep you updated, appreciate much.
_Kittur
chinhster
FWIW, I was able to reproduce the warnings on a Mac that had been wiped and recently had El Capitan freshly installed, then Xcode 7.1.1, then XE Composer 2016 Update 1. In addition, I always test new versions of Xcode and icc on a VM before I deploy to my development Mac and the VM I used is a clean El Capitan install as well. I was able to reproduce the problem on the El Capitan VM too. You should try to reproduce the problem on a stock Mac.
KitturGanesh
@chinhster:
Hi, thanks yes, we're able to reproduce the issue as well and the issue filed with the developers who'll work on a fix. I'll keep you updated as soon as the release with the fix is out. Again, thanks for all the feedback and appreciate your patience till then.
Kittur
chinhster
I figured out how to reproduce the ipo warnings.
foo.c:
#include <stdio.h>
        return 0;
> icc --version
> icc -x c -arch x86_64 -mmacosx-version-min=10.7 -O3 -w1 -std=c99 -openmp -fvisibility=hidden -fp-model precise -fno-rtti -fno-inline -lncurses -multiply_defined warning -static-intel -openmp -framework Cocoa -lstdc++ -c foo.c
> /usr/local/bin/icpc-16.0.111 -arch x86_64 foo.o -mmacosx-version-min=10.7 -lncurses -static-intel -qopenmp -stdlib=libc++ -framework Cocoa -lstdc++ -o foo
ipo: warning #11013: can not find -framework Cocoa
> icc --version
> /usr/bin/icpc-15.0 -arch x86_64 foo.o -mmacosx-version-min=10.7 -lncurses -static-intel -qopenmp -stdlib=libc++ -framework Cocoa -lstdc++ -o foo
chinhster
KitturGanesh
Yes, it's a double post but thanks much. We could reproduce the ipo warnings as well, appreciate much. The developer is already investigating and will address a fix for this issue. Again, I'll let you know as soon as the release with a fix is out.
Kittur
Royi
After all this,
How can one distribute an Application (Executable or Dynamic Library) which uses Intel OpenMP to work on any computer?
It means one must distribute the application file + libiomp5.dylib.
Is putting them in the same folder enough (For Executable? For Dynamic Library?) or one must put "libiomp5.dylib" in a folder defined by "DYLD_LIBRARY_PATH"?
What are the default folders defined in "DYLD_LIBRARY_PATH"?
Is one of them can be written into without special rights?
Thank You.
chinhster
Royi wrote:
After all this,
We've been using -static-intel -qopenmp for years to build a statically linked executable that does not require libiomp5.dylib. Despite Kittur's recommendation against it (which I can't find in the documentation), we'll continue to do so until it stops working. I really hate dependencies and feel most applications should be able to run without requiring an installer.
KitturGanesh
@Royi:
You can use the DYLD_LIBRARY_PATH to set the path to where the libraries are placed on the system including placing in the folder where the application is run etc. and the compiler at runtime should find the library based on the search path set in the DYLD_LIBRARY_PATH variable. BTW, the link https://software.intel.com/en-us/articles/intelr-composer-redistributable-libraries-by-version points to the redistributable libraries one can download for the product version as well.
@chinster:  Thanks for your comments. If you look at the documentation page at: https://software.intel.com/en-us/node/522690 and under "Command-Line Examples, OS X*" you'll notice the recommendation: "By default, the Intel® C++ Compiler performs a dynamic link of the OpenMP* libraries. To perform a static link (not recommended), add the option -openmp-link static. The Intel® C++ Compiler option -openmp-linkcontrols whether the linker uses static or dynamic OpenMP* libraries on Linux* and OS X* systems (default is -openmp-link dynamic)."
It's the developers choice to link statically but the recommendation as I eluded to earlier was to avoid any issues that might cause"multiple libraries to be linked" just in case which can cause unpredictable results, that's all.
_Kittur
Royi
@Kittur,
The problem is it doesn't even run on the same computer it is compiled.
Have a look here:
https://software.intel.com/en-us/forums/intel-c-compiler/topic/603144
I'm really frustrated and no one at Intel give us solution.
KitturGanesh
@Royi:  Thanks, just saw the link you mentioned in your post.  I've asked the library support engineer to respond to your question on static linking issue with IPP and should get back to you soon.
@Mathew, @chinster:    Regarding the issue with DYLD_LIBRARY_PATH issue a new KB article with a workaround was just published. You can go over and see if the workaround works as well. Again, the workaround should work with 2016 Update 1 release, thx. The link to the article is:
       https://software.intel.com/articles/os-x-1011-support-in-intel-parallel-studio-xe-2016
_Kittur
chinhster
_Kittur
From the KB:
... an application built with Intel® Parallel Studio version 2016 (Update 1) or earlier might not work since it is unable to locate dependent libraries such as libiomp5.dylib.
So you're saying had my app been dynamically linked to libiomp.dylib and a user upgraded to El Capitan, my app would've no longer worked on their Mac? That KB reinforced why I'm sticking with statically linking.
KitturGanesh
@chinster:  The fix for that issue (described in the KB) is coming in the next update 2 release but the workaround provided with the rpath option in the article should work until then.
_Kittur
KitturGanesh
Hi all,
Just letting you know that this issue is fixed in the latest 16.0 update 2 release which you can download and test it out. Thanks for bringing this issue to our attention and patience through this issue as well.
_Kittur
chinhster
I still get warnings when built using Xcode 7.2.1 with icc (ICC) 16.0.2 20160204:
Ld /Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS/stata-mp normal x86_64
    cd /Users/cqn/projects/stata/src/mac
    export MACOSX_DEPLOYMENT_TARGET=10.7
    /usr/local/bin/icpc-16.0.146 -arch x86_64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.11.sdk -L/Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS -L/Users/cqn/projects/stata/src/mac/../../olibxl -L/Users/cqn/projects/stata/src/mac/../../odistr -L/Users/cqn/projects/stata/src/mac/../../olibharu -L/Users/cqn/projects/stata/src/mac/../ICU/osxx86_64/lib -F/Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS -filelist /Users/cqn/projects/stata/build/stata.build/Release/stata-mp.build/Objects-normal/x86_64/stata-mp.LinkFileList -mmacosx-version-min=10.7 -lncurses -multiply_defined warning -static-intel -qopenmp -stdlib=libc++ -fobjc-link-runtime -framework Cocoa /Users/cqn/projects/stata/odistr/distr.a -lhpdfs /Users/cqn/projects/stata/olibxl/libxl.a -lstdc++ -licuio -liculx -licuuc -licui18n -licule -licutu -licudata -o /Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS/stata-mp
ipo: warning #11013: can not find -framework Foundation
However, I no longer get warnings when following the example I provided in message #27 above using icc 16.0.2.
I also still get warnings when generating dSym files:
GenerateDSYMFile /Users/cqn/projects/stata/stata/StataMP.app.dSYM /Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS/StataMP
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/dsymutil /Users/cqn/projects/stata/stata/StataMP.app/Contents/MacOS/StataMP -o /Users/cqn/projects/stata/stata/StataMP.app.dSYM
warning: (x86_64) /nfs/fx/proj/openmp/promo/20151208/tmp/mac_32e-rtl_5_nor_sta.rel.41.c0.s0....h0-fxeomac08/libtbbmalloc/backend.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20151208/tmp/mac_32e-rtl_5_nor_sta.rel.41.c0.s0....h0-fxeomac08/libtbbmalloc/backref.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20151208/tmp/mac_32e-rtl_5_nor_sta.rel.41.c0.s0....h0-fxeomac08/libtbbmalloc/frontend.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20151208/tmp/mac_32e-rtl_5_nor_sta.rel.41.c0.s0....h0-fxeomac08/libtbbmalloc/large_objects.o unable to open object file: No such file or directory
warning: (x86_64) /nfs/fx/proj/openmp/promo/20151208/tmp/mac_32e-rtl_5_nor_sta.rel.41.c0.s0....h0-fxeomac08/libtbbmalloc/tbbmalloc.o unable to open object file: No such file or directory
KitturGanesh
@chinhster:  Thanks, I've passed on your feedback to the developer and will  touch base with you as soon as I've an update from their investigation. Appreciate your patience through this.
Kittur
chinhster
I wanted to point out that with Xcode 6.4 and icc 16.0.2, I don't get the ipo warnings. I only get the dSYM warnings.
KitturGanesh
Thanks @chinster, yes that's what I assumed as well and have passed that on to the developers - appreciate much.
_Kittur
