I was adviced by intel support to post here, strange as it is a installation issue.
< Intel® Parallel Studio XE Professional Edition 2016 (Trial) web-install fails (chrashes) at "Loading config_itac.xml". And i am running it as Admin and all that shit. I did try the full version and it also failed the same way. I tried to bypass it by renaming config_itac.xml. But the next xml (config_advisor.xml) generated the same result.
Setup: Windows 10 Pro x64
Intel Core i7 920
VS2013 and VS2015
/Mattias
Hi Mattias,
This is a strange error that we haven't seen at all. For further investigation from our installation team, could you please attach the log files from the last run? The files are: %temp%\pset_tmp_PSXE2016_*\*.*
Kittur
Thanks Mathis for your patience and helping us (Devorah as well) in providing the log. I'll pass on the log to the install dev team as well for investigation - appreciate much.
_Kittur
@Mattias: Hi, I'll close this thread here as Devorah is handling this issue in Download, Registration, Licensing forum and has already sent you private email with instructions etc towards resolution, thanks.
_Kitttur
Thank you for the log. I will investigate this further and update you.
