Intel® C++ Compiler
Parallelization of dyadic product
Fabio_G_
I have two vectors (they can address the same vector) and I need to perform the product x*y with i,j=1..n.
What is the best way to perform this operation in parallel? I've tried
cilk_for(h=0;h<n*n;h++)r=x[h/n]*y[h%n];
but I guess it is only a naive tentative to do that. Indeed vec-report says it is uneffcient.
Fabio
TimP
Black Belt
If you wish to use Cilk(tm) Plus notation, this might be more topical on the Cilk forum.
I expect you may need to write something like
cilk_for(int j=0; j<n; ++j) r[j*n:n] = x * y[0:n];
You are right in looking for a combined parallel vector code generation (assuming large enough n to use multiple cores).
If using a recent compiler, you should get a more explicit warning than "seems inefficient" when you try a shared induction variable in cilk_for, even if you compile this as C rather than C++.
OpenMP would likely be more efficient (if less attractive), particularly on a NUMA platform.  I mention it only because you said "best way."
Fabio_G_
Hi Tim,
first thanks for the answer. About Cilk forum I guess you're right. About compiler, I have icpc v13
that, I know, is a bit old but it does its work. Should I use a more recent compiler? There is a "free"
version available? I could download the version I have a couple of years ago from the Intel website
and I am used to install that.
Strictly, speaking about the code you proposed I guess it is ok for what I need. I am just a final user
running extensive numerical simulations so the important is that works fine. I know few things about
OPENMP so...
Thank you!
