If you link with the multi-threaded libraries then new/delete/malloc/free/etc... will be multi-thread safe.
The other "gotcha's" are standard multi-threaded issues that exist with regular and irregular data applications. For shared variables, this may require using the atomic<...> variant and/or using Interlocked...(&var, ...) functions and/or critical sections. Note, look at the documentation for std:: classes/member functions as these are (may) not always thread safe.
Memory allocations and deallocations pass through a critical section (when linking with mt/md libraries). If you are performing a large number of allocation and deallocation (new/delete) of same (and/or similar) sized objects then look into using either a scalable allocator (TBB, ?Boost, ...) or write your own pool of available objects allocator. This is relatively easy to do.
Jim Dempsey
