The following block is passed to makefiles to set the parameters for compilations--
.SUFFIXES: .f90 .c .o .f90.o : -@echo `head -n 10 $< | grep -i module | grep -v '!' | tr 'A-Z' 'a-z' | sed 's/module//' | tr -d ' '`.${MEXT} | xargs rm -f -@rm -f $*.o ${F90} ${FDEBUGFLAGS} -c $< .c.o : -@rm -f $*.o ${CC} ${CDEBUGFLAGS} ${INCLUDEDIRS} -c $< %.o : %.mod % :: RCS/%,v .PRECIOUS: %.o # the following line suppresses excess print when using gmake MAKEFLAGS += --no-print-directory MAKDEP = makedepf90 # # Intel compiler # Edit SCALE to the path of the parent directory that this file is in SCALE = %Scale_Dir% SOURCE = ${SCALE}/src OBJECT = ${SCALE}/%Sys% LIBL = ${LIBDIR}/libscale.a EXTRA_OBJS = EXTRA_LIBS = CC = cc CFLAGS = -O -m32 CDEBUGFLAGS = ${CFLAGS} AR = ar ARFLAGS = rv AWK = awk FC = ifort F90 = ifort DFLAGS = -std95 -us -lowercase -traceback FFLAGS = $(DFLAGS) -fixed F90FLAGS = $(DFLAGS) -free FOPT = -O3 FHP = -g FALP = ${FOPT} FNOPT = -g FAJAX = $(F90FLAGS) $(FOPT) FSAVE = -save UFLAG = LDFLAGS = -i-static CLDFLAGS = -m32 RANLIB = ranlib DFLT = fort. MODL = -I MEXT = mod DATA = $(SCALE)/data CMDS = $(SCALE)/cmds LIBDIR = $(OBJECT)/lib BINDIR = $(OBJECT)/bin DATADIR = $(OBJECT)/data SCALELIB = $(LIBDIR)/libscale.a MIPLIB = $(LIBDIR)/libmip.a MARSLIB = $(LIBDIR)/libmars.a K5LIB = $(LIBDIR)/libkenova.a K6LIB = $(LIBDIR)/libkenovi.a ENDIAN15 = "FORT_CONVERT15=BIG_ENDIAN" # end IntelTwo programs that are only c code do not get linked statically. At runtime they look for the Intel library libimf.so. What parameter needs modificaiton so that the c executables will be statically linked? The compile, install and error messages are as follows--
making all in legend... Date and Time Tue Aug 14 11:36:17 EDT 2007 icc -O -m32 -I/scale/scale5.1/src/include -c /scale/scale5.1/src/legend/legend.c icc -o legend legend.o -m32 -L/scale/scale5.1/Linux_2/lib -lgd -lpng -lz -lm icc -O -m32 -I/scale/scale5.1/src/include -c /scale/scale5.1/src/legend/wpng.c icc -O -m32 -I/scale/scale5.1/src/include -c /scale/scale5.1/src/legend/writepng.c icc -o wpng wpng.o writepng.o -m32 -L/scale/scale5.1/Linux_2/lib -lpng -lz -lm making all in origen... making install in legend... Date and Time Tue Aug 14 11:49:45 EDT 2007 cp legend /scale/scale5.1/Linux_2/bin/legend /scale/scale5.1/cmds/upd_qatable /scale/scale5.1/Linux_2/data awk legend p /scale/scale5.1/Linux_2/bin /scale/scale5.1/cmds Linux_2 cp wpng /scale/scale5.1/Linux_2/bin/wpng /scale/scale5.1/cmds/upd_qatable /scale/scale5.1/Linux_2/data awk wpng p /scale/scale5.1/Linux_2/bin /scale/scale5.1/cmds Linux_2 wpng: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory legend: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directoryRobert McBroom
Have you tried adding either "-static" or "-static-intel" to your link line?
Dale
Dale
