Intel® C++ Compiler
7877 Discussions
Parsing Error templated constexpr member variable
Mueller__Tobias
Description:
When intializing a static constexpr class member variable using a brace-enclosed expression, compilation fails with error "expected a ")"".
Affected Versions:
icpc (ICC) 19.1.0.166 20191121
Minimal example:
class Test
template< typename Foo >
static constexpr bool UseSMPAssign_v =  (true) ;
int main(int argc, char** argv)
    return 0;
Expected Result:
Minimal example compiles without errors
Actual Result:
Compilation Fails with
testmain2.cpp(4): error: expected a ")"
compilation aborted for testmain2.cpp (code 2)
Other Compilers:
GCC 8.3 and 9.2 are compiling the example
Note:
Omitting the Braces fixes the issue, but syntactically there should be nothing wrong adding them.
PrasanthD_intel
We have also observed the error at our end. This seems to be a bug with the compiler.
Thanks for reporting. We will forward this issue to the respective engineering team.
Prasanth
Viet_H_Intel
I have submitted this bug to our FrontEnd (CMPLRIL0-32644). In the meantime, can you remove the () as a workaround?
Mueller__Tobias
Thank you for submitting the bug. Unfortunately, trying to implement the workaround, I found another one, which looks related, but prevents me from using templated static constexpr member variables for SFINAE (and therefore the blaze-library) with icpc.
It seems like any bracketed expression in the assignment will fail compiling with the above error.
Minimal example:
class Test
static constexpr bool UseSMPAssign_v =  (true || false) && true ;
    return 0;
Expected Result:
Actual Result:
Other Compilers:
Note:
() are needed here to logically structure the expression without relying on which order operators are executed according to the standard. Pretty sure, that there are cases constructible , which do not work without ().
Viet_H_Intel
I see. Hopefully, the fix will be in the next update compiler.
Mueller__Tobias
The fix apparently did not make it into the latest version (19.1.1.217)
Viet_H_Intel
Sorry for the inconvenient; 19.1.1.217 was built on Mar-6 (same day that this issue reported). Hence the fix couldn't be able to make it in.
Mueller__Tobias
Bug is still present in ICPC 19.1.2.254.
Viet_H_Intel
It will be fixed in the next major release compiler.
Viet_H_Intel
This issue is fixed in oneAPI2021.2.
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
I am going to close this thread.
