Intel® C++ Compiler
7956 Discussions
Performance of SSE4 instructions is not faster?
missing__zlw
I am experiencing some SSE instructions, such as __mm_dp_ps and __mm_blend_ps, performance issues.
The problem is when I move from my old combination of _mm_add_ps, _mm_mult_ps and _mm_shuffle_ps to __mm_dp_ps and __mm_blend_ps, the overall performance is about the same, or slightly worse.
Although the total instruction number has reduced in my example. I had 18 multiply, 13 add, 1 movehl, 1 shuffle before. Now I have 14 dot product. 3 add, 6 blend and 2 shuffles.
This is done in a highly repeated loop. The instruction count is for each iteration. My data accumulation is for 6, so I need to use two registries.
The tests are conducted on Linux, with SNB, NHLM and Westmere machines. They all share the same behavior.
Any help? Thanks.
jimdempseyatthecove
Examine your code to see how the ports are utilized. Intel has a tool that attemptsto do this.Although your new code "uses two registers" it may work faster using more registers as you can often do additional workduring latencies.
Jim Dempsey
missing__zlw
Thanks. Could you let me know the name of this Intel tool?
