At first, My english is poor,I am chinese guy.
Intel C++ compiler produce image is faster than MS VC++ OR GCC ,but but Intel C++ compiler isn't stable,sometimes /O2 bug ,sometimes ipo compile fail,GCC and VC++ don't meet such case. especially MS VC++ is very very stable,at least ,for me,never appear above situation.
for example,AAC faad2 library, icl /O2 compile success,when I play 6 channel AAC file with ffdshow load faad2 decode,it produce glitch,but icl with /Od or /O1 is OK.whatever VC++ compile no problem. ipo failure frequently occur too many to enumerate.
In addition,Intel C++ compiler should have more compatibility for Microsoft Visual Studio IDE and VC++ compiler ,because Visual Studio is good developer platform (of course,sometimes it crash.) . even I use it develop linux program :) . target MS technology C++ project is numerous,so VC++ maximum compatibility is absolutely necessary.
I hope Intel C++ compiler team improve compiler stability and MS compatibility,lose stability in order to optimized speed,It is very very sheer absurdity!!!
Which version of icl and vc are you using? I'm investigating the faad2 problem. Could you attach an AAC file that shows the problem? Or a link would be fine.
For other compatibility issues, could you give more detail info?
Thanks!
