Intel® C++ Compiler
Position of declarations
gib
New Contributor II
Hi, I'm compiling with icl some code that has previously been compiled with gcc. I'm getting errors because icl doesn't like declarations appearing after executable statements in a function. I can fix these errors by moving the declarations to the top of the functions, but I'm wondering is there is a compiler option that would take care of it. The source files have '.c' extension, and I'd rather not change that.
Gib
Om_S_Intel
As long as you follow C language syntax, icc should compile without issue. The icc works for me.
$ cat hello.c
//hello.c
#include
int main()
printf("Hello World...!!!\n");
int x, y, z;
x = 5;
y = 10;
z = x+y;
float fx;
fx = 3.0* x;
printf("x = %d, y = %d, z = %d, fx = %f\n", x, y, z, fx);
return 0;
$ icc hello.c
$ ./a.out
Hello World...!!!
x = 5, y = 10, z = 15, fx = 15.000000
$ icc -V
Intel C Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100128 Package ID: l_cproc_p_11.1.066
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
$ uname -a
Linux dpd22 2.6.18-52.el5 #1 SMP Wed Sep 26 15:26:44 EDT 2007 x86_64 x86_64 x86_64 GNU/Linux
Om_S_Intel
It will help if you couldpost test case.
Milind_Kulkarni__Int
New Contributor II
The workaround is to use:-- /Qstd=c99 option in Windows* . In Linux*, this option is not required.
gib
New Contributor II
Your hello.c gives errors on Windows. It compiles as hello.cpp.
gib
New Contributor II
Thanks Milind. My Makefile had -std=c99, not quite the same thing. It works now.
gib
New Contributor II
I can use /Qstd=c99 when compiling with icl, but because of the makefile problems I've encountered (see my other thread) I am now trying to build this application using MS Visual Studio. I've tried adding the following to Configuration Properties > C/C++ > Command line > Additional options:
-Qstd:c99
/Qstd:c99
-Qstd=c99
/Qstd=c99
-std:c99
-std=c99
/Qc99
but none works.
Since the help docs say of Qstd that
IDE Equivalent
Windows: Language > Enable C++0x Support
I looked for such an option in the project properties, but didn't find it.
Is there a way to get the effect of /Qstd=c99 in MSVS?
New Contributor II
When using MSVS, it seems you forgot to change to Intel compiler. so its using cl compiler, for which /Qstd=c99 does not work. To change the compiler, right-click Project in the Solution Explorer Window, and > Parallel Composer> Use Intel C++. Then the option will work.
If you want to work with MS compiler, then go to Properties>C/C++>Advanced>Compile As , and set as C++ code (/TP) option, and it will work, for icl as welll as cl. Hope it works in your case too.
gib
New Contributor II
I was just about to say "Do you think I'm stupid?" then I checked and found that I am! I didn't even realize that I had MSVC installed - this is my first foray into C for a few years.
New Contributor II
:) yes, you need to integrate the Intel Compiler to MSVS , if you have not already done. And check whether you can switch to Intel compiler in Visual Studio.
gib
New Contributor II
Yes, it was a single button click to switch MSVS over to Intel C++. I'm still amazed that I hadn't noticed that the compilation was not using the Intel compiler.
