Intel® C++ Compiler
Possible ICC>2021 C++ compiler bug
VivienC
When compiling/running this code
#include <iostream>
struct Aok1{
    std::string s {"foobar"};
    int i{42};
    operator std::string (){ return s;} // return by value
struct Aok2{
    int i{42};
    operator const std::string & ()const{ return s;} // const ref
struct Ako{
    int i{42};
    operator std::string & (){ return s;} // non-const ref
int main(int argc, char *argv[])
    std::cout << "---------------" << std::endl;
    Aok1 a;
    std::cout << "first call" << std::endl;
    const std::string b = (std::string)a;
    std::cout << b << std::endl;
    std::cout << "second call" << std::endl;
    const std::string c = (std::string)a;
    std::cout << c << std::endl;
    std::cout << "voila..." << std::endl;
    Aok2 a;
    Ako a;
    return 0;
you will end-up with the following result
first call
foobar
second call
foobar
voila...
first call
foobar
second call
foobar
voila...
first call
foobar
second call
voila...
It seems the compiler is "moving" when a non-const reference cast operator is used here.
This won't happend with gcc, clang or with previous release of intel c++ compiler.
godbolt link : https://godbolt.org/z/xxb74qccM
SeshaP_Intel
Hi
We have tried the latest version icc (2021.7.0) to run this program. And it is working as expected.
Please find the attached screenshot for the results.
Please try the latest version and let us know if you still face any issues.
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks and Regards,
SeshaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
