On icl I use /fast /Qopenmp /fp:precise /fp:double.
On gcc I use -O3 -ffast-math -fopenmp.
I noticed that if I remove OpenMP it works fine. It also works if I use /O1.
The only place where I use OpenMP is in the following function:
void calc_curvature(big_vector_t *y, big_vector_t *z) {
int i, d;
#pragma omp parallel for private(i, d)
for ( i = 0 ; i < params->particle_count ; i++ ) {
for ( d = 0 ; d < 3 ; d++ ) {
z.v.a
Here, params is a global and calc_dW does not change anything in y.
It is a physical simulation. The summation is the force. In the newer compiler the force is much less than it should be. It is not noticeable in the first cycles, but as the simulation goes on, the results differ a lot.
P.S. This site is very very slow. I get several time-outs and server errors. Are you experiencing problems?
It would nice if you can help us with small butcomplete test case to investigate the issue.
void calc_membrane(big_vector_t *y, big_vector_t *z) {
int i, d;
element_t e;
double dW[3][3];
#pragma omp parallel for private(i, d, e, dW)
for ( i = 0 ; i < params->triangle_count ; i++ ) {
e.X[0] = params->reference[params->triangle.node[0]].x;
e.X[1] = params->reference[params->triangle.node[1]].x;
e.X[2] = params->reference[params->triangle.node[2]].x;
e.x[0] = y[params->triangle.node[0]].x;
e.x[1] = y[params->triangle.node[1]].x;
e.x[2] = y[params->triangle.node[2]].x;
dW[0]
dW[1]
dW[2]
#pragma omp critical
z[params->triangle.node[0]].v.a
z[params->triangle.node[1]].v.a
z[params->triangle.node[2]].v.a
If I remove these two pragmas, the code works fine. And, as I said before, it also works fine with icl 11.1, gcc or /O1.
I am sorry I can't provide a small complete test case. My code is quite big. The source code is over 100KB.
[cpp]void calc_membrane(big_vector_t *y, big_vector_t *z) { #pragma omp parallel for for (int i = 0 ; i < params->triangle_count ; i++ ) { element_t e; double dW[3][3]; e.X[0] = params->reference[params->triangle.node[0]].x; e.X[1] = params->reference[params->triangle.node[1]].x; e.X[2] = params->reference[params->triangle.node[2]].x; e.x[0] = y[params->triangle.node[0]].x; e.x[1] = y[params->triangle.node[1]].x; e.x[2] = y[params->triangle.node[2]].x; for (int d = 0 ; d < 3 ; d++ ) { dW[0]Jim Dempsey= calc_dW(e,0,d) / params->particle[params->triangle.node[0]].m ; dW[1] = calc_dW(e,1,d) / params->particle[params->triangle.node[1]].m ; dW[2] = calc_dW(e,2,d) / params->particle[params->triangle.node[2]].m ; }
for (int d = 0 ; d < 3 ; d++ ) { z[params->triangle.node[0]].v.a-= dW[0] ; z[params->triangle.node[1]].v.a -= dW[1] ; z[params->triangle.node[2]].v.a -= dW[2] ; }
} } } [/cpp]
[bash]membrane.c membrane.c(509): error: expected an expression for (int i = 0 ; i < params->triangle_count ; i++ ) { ^ membrane.c(509): error: identifier "i" is undefined for (int i = 0 ; i < params->triangle_count ; i++ ) { ^ membrane.c(522): error: expected an expression for (int d = 0 ; d < 3 ; d++ ) { ^ membrane.c(522): error: identifier "d" is undefined for (int d = 0 ; d < 3 ; d++ ) { ^ membrane.c(530): error: expected an expression for (int d = 0 ; d < 3 ; d++ ) { ^ membrane.c(509): error: OpenMP for-init does not conform for (int i = 0 ; i < params->triangle_count ; i++ ) { ^ membrane.c(509): error: OpenMP for-test does not conform for (int i = 0 ; i < params->triangle_count ; i++ ) { ^ membrane.c(509): error: OpenMP for-incr does not conform for (int i = 0 ; i < params->triangle_count ; i++ ) { ^ [/bash]
With/Qstd=c99 it compiles fine, but I still get the same results. It works on version 11.1 but not on 12.
The result is as if this function is not executed at all. Compiling it on 11.1 without this function yields the same (or very similar) results as compiling it on 12 with the function.
Edit: I just ran a test. I saved the vector "z" before and after calling the function "calc_membrane". On version 12 it is not being modified. As I said, it's like the function is not executed at all.
It loads some data and runs my function. The contents of the vector z are saved before and after calling the function. Without openmp it works fine, but with it the vector remains unchanged.
There is also a batch file with the command line I am using.
I get compilation error with Intel compiler 12.0 when compiling attached testcase.
c:\>icl test.c /fast /Qopenmp /fp:precise /fp:double
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.1.127 Build 20101116
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
test.c
ipo: remark #11001: performing single-file optimizations
ipo: remark #11006: generating object file C:\Users\opsachan\AppData\Local\Temp\
ipo_772.obj
(0): internal error: backend signals
icl: error #10014: problem during multi-file optimization compilation (code 4)
It's not a problem with my code. It's an internal error. Seems to be a bug in the compiler.
I see you are using version12.0.1.127. Try using the latest one: 12.0.2.154.
Om
Two files are created when you run the program.bug_00000.txt is all zeros as it should be. bug_00001.txt should have many non-zero values, but it is also all zeros when you use OpenMP. It shows that the vector is not being modified when OpenMP is used.
BTW, I am using Windows 7 x64 on a Core i7 930.
The private variables are constucted using default constructor by each thread.The array dW[3][3] in private list seems to be incorrect.
You may changed your codeas given below and try.
// double dW[3][3];
//#pragma omp parallel for private(i, d, e, dW)
#pragma omp parallel for private(i, d, e)
double dW[3][3];
I tried your code. Same problem as before. "z" remains unchanged when I use OpenMP.
Once again, this code:
- works on version 11.1 with or without OpenMP
- works on GCC with or without OpenMP.
- works on version 12 without OpenMP.
- fails on version 12 with OpenMP.
And remember that it caused an "internal error" on an earlier release of the v12 compiler.
Small update:
- I tried the code with Microsoft Visual Studio 9.0. It works fine.
- With Intel v11.1 on Linux also works fine.
- With Intel v12 on Linux I get the same problem.
I modified the test case (attached). It now shows on screen the differences between running the same code with and without openmp.
If I compile with version 11.1.070 I get:
calculating with openmp
zeroes: 57 non_zeroes: 1869
calculating without openmp
Which is correct. With version 12.0.4.196 I get:
zeroes: 1926 non_zeroes: 0
Which is wrong. Notice that with openmp the vector does not get updated at all. It remains all zero.
Any updates on the status of this issue?
This could indicate that there are problems with the code or with its usage of OpenMP directives.
[bash]s:langItalo>cl /Od /openmp test.c /Fetest Microsoft C/C++ Optimizing Compiler Version 16.00.30319.01 for x64 Copyright (C) Microsoft Corporation. All rights reserved. test.c Microsoft Incremental Linker Version 10.00.30319.01 Copyright (C) Microsoft Corporation. All rights reserved. /out:test.exe test.obj s:langItalo>.test calculating with openmp zeroes: 1926 non_zeroes: 0 calculating without openmp zeroes: 1926 non_zeroes: 0 [/bash]
Strange. Are you loading the data file?
So, if Microsoft's compiler is correct, then Intel v11, with ou without OpenMP, and v12 without OpenMP are wrong?
Here is what I get using Microsoft:
Setting environment for using Microsoft Visual Studio 2008 Beta2 x64 tools.
Microsoft C/C++ Optimizing Compiler Version 15.00.30729.01 for x64
test.c
Microsoft Incremental Linker Version 9.00.30729.01
/out:solver.exe
test.obj
