Intel® C++ Compiler
Possible bug with variadic templates and initializer list?
Raffael_C_
If I try to compile
[cpp]
#include<initializer_list>
#include<iostream>
void foo(std::initializer_list<int> a) {
  for(auto b : a)
    std::cout << b << std::endl;
template<class... VALUES>
void callFoo(VALUES... values) {
  foo({values...});
int main() {
  callFoo(1,2,3);
[/cpp]
Intel Composer XE 2014 (on Windows) says:
[cpp]
error: no instance of function template "foo" matches the argument list
            argument types are: (A<double, int>)
    foo<double, int>(A<double, int>());
[/cpp]
I believe this is a bug since it compiles without problems using gcc 4.8.2. and clang 3.4 on linux. Would it be possible to fix this in one of the upcoming releases?
Raffael
Judith_W_Intel
I can't reproduce this. It compiles fine when I tried it with our latest 14.0 development compiler.
Are you using MSVC++ 2013 (I assume you are or else it wouldn't find the initializer_list header file)?
Are you using 14.0 Update 1? Are you using any special switches?
If I try a compiler that was released around the same time as Update 1, I see this internal error. This was fixed in December 2013.
!%  //ssgfs001/cmplrarch/SWF/deploy_14_0/x86win/20131009_000000/build/win_debug/
bin/ia32/icl -c -w -Qstd=c++11 t2.cpp
Intel(R) C++ Compiler XE for applications running on IA-32, Version 14.0 Beta Bu
ild x
Built Oct  9 2013 05:33:54 by nbtester on SCXWQA85 in d:/users/nbtester/x86win_n
ightly/branch-14_0/20131009_000000/dev
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
t2.cpp
t2.cpp(11): internal error: assertion failed: node_has_side_effects: bad node kind (shared/cfe/edgcpfe/il.c, line 20802)
    foo({values...});
compilation aborted for t2.cpp (code 4)
With our latest compiler it compiles successfully:
!% cat t2.cpp
#include<iostream>
  for(auto b : a)
  foo({values...});
int main() {
  callFoo(1,2,3);
  return 0;
!% icl -c t2.cpp
Intel(R) C++ Compiler XE for applications running on IA-32, Version 14.0 Beta Build x
Built Jan  6 2014 18:06:04 by jward4 on JWARD4-DESK in D:/workspaces/14_0cfe/dev
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
t2.cpp
14.0 Update 2 is due to be released any day now so I hope this is fixed when you try it out.
But I'm not sure since I can't reproduce the same error that you are seeing..
Judy
Raffael_C_
Hi Judy,
Thanks a lot for having a look at this issue. I guess I have been a bit lazy, so here is the full description of my setup:
I have Visual Studio 2013 installed and with it comes a version of the STL that has support for initializer_lists. The exact version of MSVC is:
[cpp]
Microsoft (R) C/C++ Optimizing Compiler Version 18.00.21005.1 for x64
[/cpp]
On the Intel side I have installed Intel Composer XE 2014 SP1 Update 1 (package 139) and I compile the c++ file as follows:
[cpp]
Intel(R) Parallel Studio XE 2013 SP1
Intel(R) Composer XE 2013 SP1 Update 1 (package 139)
icl variadicInitializerList.cpp /Qstd=c++11
[/cpp]
(The environment variables have been set by executing the x64 batch script of the intel compiler:
[cpp]
C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\ipsxe-comp-vars.bat intel64 vs2013
[/cpp]
In my case this doesn't compile at all but may be it is really fixed in the next version, lets see...
Raffael
