Intel® C++ Compiler
Possible bug?
speedninja
Hi guys,
I was trying to get a hello world c++11 program going, but it seems like the non-gcc compilers don't like it very much.  I am probably doing something wrong, but I can't figure out what.  Here is the simple hello world program, along with how I am compiling it.  Both, clang and intel complained about it.  I just included clang for completeness.
--------------------- hw.cpp ------------------
#include <thread>
#include <iostream>
int main()
    auto hello_world = [] () { std::cout << "Hello world" << std::endl; };
    std::thread thr(hello_world);
    thr.join();
    return 0;
$ g++ -std=c++11 hw.cpp -lpthread && ./a.out
Hello world
$ clang++ -std=libc++ -std=c++11 hw.cpp -lpthread && ./a.out
pure virtual method called
terminate called without an active exception
Aborted (core dumped)
(here are the paths that the intel compiler is using)
$ icpc -std=c++11 -v -x c++ /dev/null -fsyntax-only
icpc version 13.0.1 (gcc version 4.7.0 compatibility)
/opt/intel/composer_xe_2013.1.117/bin/intel64/mcpcom -_g -mP3OPT_inline_alloca -D__HONOR_STD -D__ICC=1300 -D__INTEL_COMPILER=1300 -D__PTRDIFF_TYPE__=long "-D__SIZE_TYPE__=unsigned long" -D__WCHAR_TYPE__=int "-D__WINT_TYPE__=unsigned int" "-D__INTMAX_TYPE__=long int" "-D__UINTMAX_TYPE__=long unsigned int" -D__INTEL_CXX11_MODE__ -D__LONG_MAX__=9223372036854775807L -D__QMSPP_ -D__OPTIMIZE__ -D__NO_MATH_INLINES -D__NO_STRING_INLINES -D__NO_INLINE__ -D__GNUC_GNU_INLINE__ -D__STRICT_ANSI__ -D__GXX_EXPERIMENTAL_CXX0X__ -D__GNUG__=4 -D__GNUC__=4 -D__GNUC_MINOR__=7 -D__GNUC_PATCHLEVEL__=0 -D__LP64__ -D_LP64 -D_GNU_SOURCE=1 -D__DEPRECATED=1 -D__GXX_WEAK__=1 -D__GXX_ABI_VERSION=1002 "-D__USER_LABEL_PREFIX__= " -D__REGISTER_PREFIX__= -D__INTEL_RTTI__ -D__EXCEPTIONS=1 -D__unix__ -D__unix -D__linux__ -D__linux -D__gnu_linux__ -B "-_Asystem(unix)" -D__ELF__ -D__x86_64 -D__x86_64__ "-_Acpu(x86_64)" "-_Amachine(x86_64)" -D_MT -D__INTEL_COMPILER_BUILD_DATE=20121010 -D__INTEL_OFFLOAD -D__i686 -D__i686__ -D__pentiumpro -D__pentiumpro__ -D__pentium4 -D__pentium4__ -D__tune_pentium4__ -D__SSE2__ -D__SSE__ -D__MMX__ -_k -_8 -_l -_a -_b -n --gnu_version=470 -_W5 --gcc-extern-inline -p --bool -tused -mGLOB_eh_linux -x --c++0x --multibyte_chars --array_section --simd --simd_func --offload_mode=1 --offload_target_names=mic,MIC --bool -mP1OPT_print_version=FALSE -mP1OPT_version=13.0-intel64 -mGLOB_diag_file=null.diag /dev/null
#include "..." search starts here:
#include <...> search starts here:
/opt/intel/composer_xe_2013.1.117/compiler/include/intel64
/usr/include/c++/4.7
/usr/include/c++/4.7/x86_64-linux-gnu
/usr/include/c++/4.7/backward
/usr/local/include
/usr/lib/gcc/x86_64-linux-gnu/4.7/include
/usr/lib/gcc/x86_64-linux-gnu/4.7/include-fixed
/usr/include
/usr/include/x86_64-linux-gnu
End of search list.
$ icpc -std=c++11 hw.cpp -lpthread && ./a.out
/usr/include/c++/4.7/type_traits(1048): error: function "lambda []()->void::operator=(const lambda []()->void &)" (declared at line 6 of "hw.cpp") cannot be referenced -- it is a deleted function
static decltype(declval<_Tp1>() = declval<_Up1>(), __one())
detected during:
instantiation of class "std::__is_assignable_helper<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 1062
instantiation of class "std::is_assignable<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 117
instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_assignable<lambda []()->void &, lambda []()->void &&>, _B2=std::__is_nt_assignable_impl<lambda []()->void &, lambda []()->void &&>]" at line 1110
instantiation of class "std::is_nothrow_assignable<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 1140
instantiation of class "std::__is_nt_move_assignable_impl<_Tp, false> [with _Tp=lambda []()->void]" at line 1146
[ 2 instantiation contexts not shown ]
instantiation of class "std::_Tuple_impl<_Idx, _Head, _Tail...> [with _Idx=0UL, _Head=lambda []()->void, _Tail=<>]" at line 374 of "/usr/include/c++/4.7/tuple"
instantiation of class "std::tuple<_Elements...> [with _Elements=<lambda []()->void>]" at line 1601 of "/usr/include/c++/4.7/functional"
instantiation of class "std::_Bind_simple<_Callable (_Args...)> [with _Callable=lambda []()->void, _Args=<>]" at line 1619 of "/usr/include/c++/4.7/functional"
instantiation of "std::_Bind_simple_helper<_Callable, _Args...>::__type std::__bind_simple(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 135 of "/usr/include/c++/4.7/thread"
instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp"
/usr/include/c++/4.7/type_traits(1103): error: function "lambda []()->void::operator=(const lambda []()->void &)" (declared at line 6 of "hw.cpp") cannot be referenced -- it is a deleted function
: public integral_constant<bool, noexcept(declval<_Tp>() = declval<_Up>())>
detected during:
instantiation of class "std::__is_nt_assignable_impl<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 117
instantiation of class "std::is_nothrow_move_assignable<_Tp> [with _Tp=lambda []()->void]" at line 117
instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_nothrow_move_assignable<lambda []()->void>, _B2=std::is_nothrow_move_assignable<std::_Tuple_impl<1UL>>]" at line 332 of "/usr/include/c++/4.7/tuple"
/usr/include/c++/4.7/bits/alloc_traits.h(56): error: expression must have a constant value
static const bool __value = _S_chk<_Alloc, _Tp>(nullptr);
detected during:
instantiation of class "std::__alloctr_rebind_helper<_Alloc, _Tp> [with _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, _Tp=std::_Sp_counted_ptr_inplace<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, __gnu_cxx::_S_atomic>]" at line 63
processing of template argument list for "std::__alloctr_rebind" based on template arguments <std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, std::_Sp_counted_ptr_inplace<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, __gnu_cxx::_S_atomic>> at line 201
instantiation of type "std::allocator_traits<_Alloc>::rebind_alloc<std::_Sp_counted_ptr_inplace<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>]" at line 203
instantiation of type "std::allocator_traits<_Alloc>::rebind_traits<std::_Sp_counted_ptr_inplace<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>]" at line 520 of "/usr/include/c++/4.7/bits/shared_ptr_base.h"
instantiation of "std::__shared_count<_Lp>::__shared_count(std::_Sp_make_shared_tag, _Tp *, const _Alloc &, _Args &&...) [with _Lp=__gnu_cxx::_S_atomic, _Tp=std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, _Args=<std::_Bind_simple<lambda []()->void ()>>]" at line 998 of "/usr/include/c++/4.7/bits/shared_ptr_base.h"
instantiation of "std::__shared_ptr<_Tp, _Lp>::__shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, _Lp=__gnu_cxx::_S_atomic, _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, _Args=<std::_Bind_simple<lambda []()->void ()>>]" at line 318 of "/usr/include/c++/4.7/bits/shared_ptr.h"
instantiation of "std::shared_ptr<_Tp>::shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, _Args=<std::_Bind_simple<lambda []()->void ()>>]" at line 599 of "/usr/include/c++/4.7/bits/shared_ptr.h"
instantiation of "std::shared_ptr<_Tp> std::allocate_shared<_Tp,_Alloc,_Args...>(const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, _Alloc=std::allocator<std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>>, _Args=<std::_Bind_simple<lambda []()->void ()>>]" at line 615 of "/usr/include/c++/4.7/bits/shared_ptr.h"
instantiation of "std::shared_ptr<_Tp> std::make_shared<_Tp,_Args...>(_Args &&...) [with _Tp=std::thread::_Impl<std::_Bind_simple<lambda []()->void ()>>, _Args=<std::_Bind_simple<lambda []()->void ()>>]" at line 191 of "/usr/include/c++/4.7/thread"
instantiation of "std::shared_ptr<std::thread::_Impl<_Callable>> std::thread::_M_make_routine(_Callable &&) [with _Callable=std::_Bind_simple<lambda []()->void ()>]" at line 135 of "/usr/include/c++/4.7/thread"
/usr/include/c++/4.7/bits/alloc_traits.h(201): error: incomplete type is not allowed
using rebind_alloc = typename __alloctr_rebind<_Alloc, _Tp>::__type;
detected during:
/usr/include/c++/4.7/bits/alloc_traits.h(89): error: name followed by "::" must be a class or namespace name
typedef typename _Alloc::value_type value_type;
detected during:
instantiation of class "std::allocator_traits<_Alloc> [with _Alloc=<error-type>]" at line 521 of "/usr/include/c++/4.7/bits/shared_ptr_base.h"
compilation aborted for hw.cpp (code 2)
Kittur_G_Intel
Hi, Compile with the option -std=c++0x flag (see below) %icpc -std=c++0x main.cpp -lpthread && ./a.out Hello world
speedninja
Which version of the compiler are you using? That option seems to have the same effect as -std=c++11 $ icpc -std=c++0x hw.cpp -lpthread && ./a.out /usr/include/c++/4.7/type_traits(1048): error: function "lambda []()->void::operator=(const lambda []()->void &)" (declared at line 6 of "hw.cpp") cannot be referenced -- it is a deleted function static decltype(declval<_Tp1>() = declval<_Up1>(), __one()) ^ detected during: instantiation of class "std::__is_assignable_helper<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 1062 instantiation of class "std::is_assignable<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 117 instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_assignablevoid &, lambda []()->void &&>, _B2=std::__is_nt_assignable_implvoid &, lambda []()->void &&>]" at line 1110 instantiation of class "std::is_nothrow_assignable<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 1140 instantiation of class "std::__is_nt_move_assignable_impl<_Tp, false> [with _Tp=lambda []()->void]" at line 1146 [ 2 instantiation contexts not shown ] instantiation of class "std::_Tuple_impl<_Idx, _Head, _Tail...> [with _Idx=0UL, _Head=lambda []()->void, _Tail=<>]" at line 374 of "/usr/include/c++/4.7/tuple" instantiation of class "std::tuple<_Elements...> [with _Elements=void>]" at line 1601 of "/usr/include/c++/4.7/functional" instantiation of class "std::_Bind_simple<_Callable (_Args...)> [with _Callable=lambda []()->void, _Args=<>]" at line 1619 of "/usr/include/c++/4.7/functional" instantiation of "std::_Bind_simple_helper<_Callable, _Args...>::__type std::__bind_simple(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 135 of "/usr/include/c++/4.7/thread" instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp" /usr/include/c++/4.7/type_traits(1103): error: function "lambda []()->void::operator=(const lambda []()->void &)" (declared at line 6 of "hw.cpp") cannot be referenced -- it is a deleted function : public integral_constant() = declval<_Up>())> ^ detected during: instantiation of class "std::__is_nt_assignable_impl<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 117 instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_assignablevoid &, lambda []()->void &&>, _B2=std::__is_nt_assignable_implvoid &, lambda []()->void &&>]" at line 1110 instantiation of class "std::is_nothrow_assignable<_Tp, _Up> [with _Tp=lambda []()->void &, _Up=lambda []()->void &&]" at line 1140 instantiation of class "std::__is_nt_move_assignable_impl<_Tp, false> [with _Tp=lambda []()->void]" at line 1146 instantiation of class "std::is_nothrow_move_assignable<_Tp> [with _Tp=lambda []()->void]" at line 117 instantiation of class "std::__and_<_B1, _B2> [with _B1=std::is_nothrow_move_assignablevoid>, _B2=std::is_nothrow_move_assignable<:_TUPLE_IMPL><1UL>>]" at line 332 of "/usr/include/c++/4.7/tuple" instantiation of class "std::_Tuple_impl<_Idx, _Head, _Tail...> [with _Idx=0UL, _Head=lambda []()->void, _Tail=<>]" at line 374 of "/usr/include/c++/4.7/tuple" instantiation of class "std::tuple<_Elements...> [with _Elements=void>]" at line 1601 of "/usr/include/c++/4.7/functional" instantiation of class "std::_Bind_simple<_Callable (_Args...)> [with _Callable=lambda []()->void, _Args=<>]" at line 1619 of "/usr/include/c++/4.7/functional" instantiation of "std::_Bind_simple_helper<_Callable, _Args...>::__type std::__bind_simple(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 135 of "/usr/include/c++/4.7/thread" instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp" /usr/include/c++/4.7/bits/alloc_traits.h(56): error: expression must have a constant value static const bool __value = _S_chk<_Alloc, _Tp>(nullptr); ^ detected during: instantiation of class "std::__alloctr_rebind_helper<_Alloc, _Tp> [with _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Tp=std::_Sp_counted_ptr_inplace<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>]" at line 63 processing of template argument list for "std::__alloctr_rebind" based on template arguments <:ALLOCATOR><:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, std::_Sp_counted_ptr_inplace<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>> at line 201 instantiation of type "std::allocator_traits<_Alloc>::rebind_alloc<:_SP_COUNTED_PTR_INPLACE><:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>]" at line 203 instantiation of type "std::allocator_traits<_Alloc>::rebind_traits<:_SP_COUNTED_PTR_INPLACE><:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>]" at line 520 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_count<_Lp>::__shared_count(std::_Sp_make_shared_tag, _Tp *, const _Alloc &, _Args &&...) [with _Lp=__gnu_cxx::_S_atomic, _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 998 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_ptr<_Tp, _Lp>::__shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Lp=__gnu_cxx::_S_atomic, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 318 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp>::shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 599 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::allocate_shared<_Tp,_Alloc,_Args...>(const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 615 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::make_shared<_Tp,_Args...>(_Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 191 of "/usr/include/c++/4.7/thread" instantiation of "std::shared_ptr<:THREAD::_IMPL><_Callable>> std::thread::_M_make_routine(_Callable &&) [with _Callable=std::_Bind_simplevoid ()>]" at line 135 of "/usr/include/c++/4.7/thread" instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp" /usr/include/c++/4.7/bits/alloc_traits.h(201): error: incomplete type is not allowed using rebind_alloc = typename __alloctr_rebind<_Alloc, _Tp>::__type; ^ detected during: instantiation of type "std::allocator_traits<_Alloc>::rebind_alloc<:_SP_COUNTED_PTR_INPLACE><:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>]" at line 203 instantiation of type "std::allocator_traits<_Alloc>::rebind_traits<:_SP_COUNTED_PTR_INPLACE><:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>, std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, __gnu_cxx::_S_atomic>> [with _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>]" at line 520 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_count<_Lp>::__shared_count(std::_Sp_make_shared_tag, _Tp *, const _Alloc &, _Args &&...) [with _Lp=__gnu_cxx::_S_atomic, _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 998 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_ptr<_Tp, _Lp>::__shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Lp=__gnu_cxx::_S_atomic, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 318 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp>::shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 599 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::allocate_shared<_Tp,_Alloc,_Args...>(const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 615 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::make_shared<_Tp,_Args...>(_Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 191 of "/usr/include/c++/4.7/thread" instantiation of "std::shared_ptr<:THREAD::_IMPL><_Callable>> std::thread::_M_make_routine(_Callable &&) [with _Callable=std::_Bind_simplevoid ()>]" at line 135 of "/usr/include/c++/4.7/thread" instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp" /usr/include/c++/4.7/bits/alloc_traits.h(89): error: name followed by "::" must be a class or namespace name typedef typename _Alloc::value_type value_type; ^ detected during: instantiation of class "std::allocator_traits<_Alloc> [with _Alloc=]" at line 521 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_count<_Lp>::__shared_count(std::_Sp_make_shared_tag, _Tp *, const _Alloc &, _Args &&...) [with _Lp=__gnu_cxx::_S_atomic, _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 998 of "/usr/include/c++/4.7/bits/shared_ptr_base.h" instantiation of "std::__shared_ptr<_Tp, _Lp>::__shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Lp=__gnu_cxx::_S_atomic, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 318 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp>::shared_ptr(std::_Sp_make_shared_tag, const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 599 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::allocate_shared<_Tp,_Alloc,_Args...>(const _Alloc &, _Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Alloc=std::allocator<:THREAD::_IMPL><:_BIND_SIMPLE>void ()>>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 615 of "/usr/include/c++/4.7/bits/shared_ptr.h" instantiation of "std::shared_ptr<_Tp> std::make_shared<_Tp,_Args...>(_Args &&...) [with _Tp=std::thread::_Impl<:_BIND_SIMPLE>void ()>>, _Args=<:_BIND_SIMPLE>void ()>>]" at line 191 of "/usr/include/c++/4.7/thread" instantiation of "std::shared_ptr<:THREAD::_IMPL><_Callable>> std::thread::_M_make_routine(_Callable &&) [with _Callable=std::_Bind_simplevoid ()>]" at line 135 of "/usr/include/c++/4.7/thread" instantiation of "std::thread::thread(_Callable &&, _Args &&...) [with _Callable=lambda []()->void &, _Args=<>]" at line 8 of "hw.cpp" compilation aborted for hw.cpp (code 2) $ icpc --version icpc (ICC) 13.0.1 20121010 Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
Kittur_G_Intel
Hi, Yes, I tried the latest compiler but gcc version was 4.4.6. %icpc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.1.117 Build 20121010 Since I am getting some other problems, could you please attach the .i file to this issue so I can try out? Just compile with icpc using the option -P and it will create the .i file which you can attach Thanks much.
speedninja
the .i file is attached
Kittur_G_Intel
Hi, Thanks much for the .i file. Yes, this is a bug and I've filed the issue with our developers. I'll touch base with you as soon as I've an update on the fix. Appreciate much for your patience till then. Regards, Kittur
speedninja
Thanks for fixing this in the new release!  It works as expected now.
Casey
hw.cpp compiles fine in the newest update.
$ icpc -v
icpc version 13.1.3 (gcc version 4.7.0 compatibility)
$ icpc --version
icpc (ICC) 13.1.3 20130607
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
$ gcc --version
gcc (Gentoo 4.7.3 p1.0, pie-0.5.5) 4.7.3
Copyright (C) 2012 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ icpc -std=c++11 -lpthread -o hw hw.cpp
$ ./hw
Hello world
Kittur_G_Intel
Thank, yes this is fixed (thought I'd responded apparently not registered here)
Regards.
