Intel® C++ Compiler
7956 Discussions
Possible non standard-conforming behavior of icpc
Massimiliano_Culpo
I would like to report on a possible bug I found with the use of Expression Templates technique. A detailed description of the problem can be found here:
http://stackoverflow.com/questions/9819298/conversion-operator-implemented-with-static-cast
which is the follow-up of another thread, where you can find a piece of code that can reproduce the bug:
http://stackoverflow.com/questions/9738975/crtp-compiler-dependent-issue-with-expression-template
Massimiliano
TimP
As you seem to have a fairly complicated issue, it would be better to file a self-contained problem report on premier.intel.com. I can't even tell from that convoluted thread whether you take issue with the response you got about how to correct your issue.
Massimiliano_Culpo
The problem that was spotted has been corrected (first edit) and you can use the code that has been posted as a self-contained problem. Furthermore as the thread was getting "convoluted" I moved the core question to another thread (which is quite neat). I just want to let you know of a possible problem, and have no interest in resubmit the issue.
Have a nice day,
Massimiliano
Judith_W_Intel
I hope the example below represents your issue. I entered it into our bug tracking database as DPD200180500.
Thank you for pointing this out.
// example of infinite recursion with Intel compiler but runs ok with g++ and cl
extern "C" int printf(const char*,...);
template
struct Base {
operator const Derived&() const {
printf("in conversion operator\n");
return static_cast (*this);
class Specialization : public Base {};
template
void foo(const Base& param) {
const T& val(param);
int main()
Base b;
foo(b);
return 0;
Judy
Massimiliano_Culpo
Yes, that's exactly the issue I spotted.
Massimiliano
