I would like to report on a possible bug I found with the use of Expression Templates technique. A detailed description of the problem can be found here:
http://stackoverflow.com/questions/9819298/conversion-operator-implemented-with-static-cast
which is the follow-up of another thread, where you can find a piece of code that can reproduce the bug:
http://stackoverflow.com/questions/9738975/crtp-compiler-dependent-issue-with-expression-template
Massimiliano
Massimiliano
As you seem to have a fairly complicated issue, it would be better to file a self-contained problem report on premier.intel.com. I can't even tell from that convoluted thread whether you take issue with the response you got about how to correct your issue.
The problem that was spotted has been corrected (first edit) and you can use the code that has been posted as a self-contained problem. Furthermore as the thread was getting "convoluted" I moved the core question to another thread (which is quite neat). I just want to let you know of a possible problem, and have no interest in resubmit the issue.
Have a nice day,
Massimiliano
Have a nice day,
Massimiliano
I hope the example below represents your issue. I entered it into our bug tracking database as DPD200180500.
Thank you for pointing this out.
// example of infinite recursion with Intel compiler but runs ok with g++ and cl
extern "C" int printf(const char*,...);
template
struct Base {
operator const Derived&() const {
printf("in conversion operator\n");
return static_cast
class Specialization : public Base
template
void foo(const Base
const T& val(param);
int main()
Base
foo(b);
return 0;
Judy
Yes, that's exactly the issue I spotted.
Massimiliano
Massimiliano
