Hi, I would like know if Intel/C++/XScale compiler to Pocket PC, insert automatic preload instruction? This compiler can to schedule this instruction efficiently? Or a programmer may do it?
Thanks in advance
Mrcio
The Intel C++ Compiler supports the PLD instruction and it provides an intrinsic
void _PreLoad(unsigned long *addr);
that can b eused anfd inserted anywhere in your code.
Currently the Intel C++ Compiler does not automatically insert or schedule PLD's since their use is somewhat dependent on programmer's intent. Also the instruction cache usage analysis required to automate this would not be exactly trivial.
It has however been considered and may make it into one ofthe future compiler releases.
Rgds, Rob
