I have a problem to install Compiler for Intel64 applications. IA-32 is ok ;
Intel C++ Compiler Professional Edition for Windows* modification can continue, but take note
The following components can not be installed:
- Intel C++ Compiler for applications running on Intel 64
- Integration(s) in Microsoft Visual Studio*
- Intel Parallel Debugger Extension
- Integrated Documentation
Modification can continue; however, these components will not be installed because they require that a supported Microsoft* development tools be installed. Refer to the Release Notes for a list of the required Microsoft* development tools.
Please help me to resolve this problem, I installed Windows SDK Tools and I activated features of .NET Framework on componments of Windows.
OS : Windows Seven Professionnal.
CPU : Intel Xeon E5520 2,27 Ghz ;
RAM : 4GB 1066 Mhz DDR3 ;
Which compiler package did you install (package name w_cproc_p_11.1.xxx?)
Did you perform a full installation or customer installation?
WhichMicrosoft Visual Studio* version(s) do you have on your computer.
Hubert.
Hubert.
Yes I installed all package w_cproc_p_11.1.xxx redist_intel64 and redist_ia32.
I just want to install a version who is functionnal.
I don't want to use Visual Studio software so I installed Visual Studio C++ 2008 Express Edition.
VS express doesn't support X64 compilation.
I want to use only the command line tools of intel C++ compiler
Does I really need to install visual studio ?
Finally I install Windows SDK for Windows Server 2008 and .NET Framework 3.5 on windows 7. That solves completely the problem. I can now compile for intel64.
Thanks for your help.
