Intel® C++ Compiler
7932 Discussions
Problem compiling Eigen library (GPU offload) in a self-contained mini-app.
Christos_Kotsalos
I have a mini-app (see below) that calls an Eigen solver from a GPU accelerated region, but the compiler fails to compile it (probably compiler bug).
#include <stdio.h>
#include "Eigen/Core"
#include "Eigen/Dense"
#include "Eigen/LU"
#include <random>
// for DIM 17 and above : stack size issues
#define DIM 16
using namespace Eigen;
using MatType = Matrix<double, DIM, DIM>;
using VecType = Matrix<double, DIM, 1>;
void print_solution(VecType x, int dim)
    printf("\n");
    printf("x = ");
    for (int i = 0; i < dim; i++)
        printf("%.3f ", x(i));
    printf("\n\n");
#if defined(USE_OPENACC)
#pragma acc routine seq
#endif
#if defined(USE_OPENMP)
#pragma omp declare target
#endif
#if defined __NVCC__
__host__ __device__
#endif
void solve_offload(MatType *A, VecType *b, int dim)
    VecType x = A->partialPivLu().solve(*b);
    printf("[OpenACC]");
    #endif
    printf("[OpenMP]");
    #endif
    print_solution(x,dim);
#pragma omp end declare target
#endif
int main()
    std::random_device rd; // seeding
    std::mt19937 mt(rd());
    std::uniform_real_distribution<double> nums(-10, 10);
    MatType *A = (MatType*)malloc(sizeof(MatType));
    VecType *b = (VecType*)malloc(sizeof(VecType));
    do
        // initialization
        for(int r = 0; r < DIM; r++) {
            for(int c = 0; c < DIM; c++) {
                (*A)(r,c) = nums(mt);
            (*b)(r) = nums(mt);
    } while (!A->fullPivLu().isInvertible()); // Checking Invertibility
    printf("\n");
    printf("[Host]");
    print_solution(x,DIM);
    #pragma acc data copyin(A[0:DIM*DIM],b[0:DIM])
    #endif
    #pragma omp target data map(to:A[0:DIM*DIM],b[0:DIM])
    #endif
        #pragma acc kernels present(A,b)
        #endif
        #pragma omp target
        #endif
            solve_offload(A, b, DIM);
            // We need to wrap it around `omp declare target` or
            // `acc routine seq` to work!
            // A->partialPivLu().solve(*b);
    return 0;
To reporduce the error, I follow these steps:
  1. git clone --branch olupton/nvc++-cuda https://github.com/BlueBrain/eigen.git
  2. icpx -Ieigen -DEIGEN_DONT_VECTORIZE=1 -DEIGEN_DONT_PARALLELIZE=1 -DEIGEN_NO_CPUID -DUSE_OPENMP -qopenmp -fopenmp-targets=spir64 -o eigen_offload eigen.cpp
Using NVIDIA compilers I have managed to successfully compile this miniapp, though with Intel-oneAPI (tried it in iIntel DevCloud) I get the error below:
344 warnings generated.
LLVM ERROR: Type mismatch in constant table!
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace.
Stack dump:
0.      Program arguments: /glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link /tmp/eigen-660a10.bc /tmp/libomp-spirvdevicertl-0fd3f3.o -o /tmp/spir64-linkomp-2d06f8.bc --suppress-warnings
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x311bba)[0x55ecac9b4bba]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x30fd90)[0x55ecac9b2d90]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x31201d)[0x55ecac9b501d]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x12890)[0x7f2ad16b2890]
/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f2ad12ede97]
/lib/x86_64-linux-gnu/libc.so.6(abort+0x141)[0x7f2ad12ef801]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2e62d4)[0x55ecac9892d4]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2e6165)[0x55ecac989165]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x1c3792)[0x55ecac866792]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x1a01a5)[0x55ecac8431a5]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x197d13)[0x55ecac83ad13]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x196a62)[0x55ecac839a62]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x27e125)[0x55ecac921125]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2530d0)[0x55ecac8f60d0]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2b767c)[0x55ecac95a67c]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2b4e32)[0x55ecac957e32]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x314454)[0x55ecac9b7454]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x314df7)[0x55ecac9b7df7]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x3156dc)[0x55ecac9b86dc]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x314009)[0x55ecac9b7009]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x31413a)[0x55ecac9b713a]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2b2e31)[0x55ecac955e31]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2b24dc)[0x55ecac9554dc]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2bce3f)[0x55ecac95fe3f]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x2bc458)[0x55ecac95f458]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x18e63c)[0x55ecac83163c]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x18c1f0)[0x55ecac82f1f0]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f2ad12d0b97]
/glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm/llvm-link(+0x18b6a9)[0x55ecac82e6a9]
clang++: error: unable to execute command: Aborted
clang++: error: sycl-link command failed due to signal (use -v to see invocation)
Intel(R) oneAPI DPC++/C++ Compiler 2022.0.0 (2022.0.0.20211123)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /glob/development-tools/versions/oneapi/2022.1.2/oneapi/compiler/2022.0.2/linux/bin-llvm
clang++: note: diagnostic msg: Error generating preprocessed source(s).
Any feedback would be really appreciated.
Best,
Christos
VarshaS_Intel
We were able to reproduce your issue on Intel DevCloud using the ICPX compiler. We are working on your issue and we will get back to you soon.
Thanks & Regards,
Varsha
Christos_Kotsalos
Hi Varsha,
Thank you very much for your quick response.
I am looking forward to hearing from you regarding this compiler issue.
Best,
Christos
VarshaS_Intel
Thanks for reporting the bug.
We have reported this issue. And, the development team is looking into the issue.
Thanks & Regards,
Varsha
VarshaS_Intel
Thank you for your patience. The issue raised by you has been fixed in Intel oneAPI Base Toolkit and HPC Toolkit version(2022.3) and ICPX(2022.2). Please download and let us know if this resolves your issue.
Thanks & Regards,
Varsha
Christos_Kotsalos
Hi Varsha,
Thank you very much for letting me know. Indeed, I am now able to compile the mini-app.
Therefore, we can close this issue.
Best,
Christos
VarshaS_Intel
Glad to know that your issue is resolved.
Thanks for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Have a good day!
Thanks & Regards,
Varsha
