Hello all,
I'm using aramadillo (http://arma.sourceforge.net) to elegantly manipulate arrays. All was working well till the last version (4.650.2).
Now it fails compiling with icpc (15.0.1, Linux) pretending there is a resolution problem. The snippet code still compile fine with g++(4.9.2) and also clang (3.5) showing no error or warning.
I've filed a bug to armadillo team, but they told me it is an Intel issue.
I would be happy if any solution exists to solve this issue as I both need using armadillo and the intel compiler for speed and efficency.
Thanks in advance for any answer.
Daniel
Here is the code:
#define ARMA_DONT_USE_WRAPPER #define ARMA_DONT_USE_HDF5 #define ARMA_DONT_USE_BLAS #include <armadillo> using namespace std; using namespace arma; #define LEN 50 int main() { mat::fixed<LEN,9> beta; vec::fixed<LEN> alpha; mat::fixed<LEN,9> ash1; ash1=repmat(alpha,1,9)-beta; return(0); }
and the compilation error:
~ $ icpc -I armadillo-4.650.2/include/ bugarma.cpp bugarma.cpp(17): error: more than one operator "=" matches these operands: function template "const arma::Mat<double> &arma::Mat<eT>::operator=(const arma::eGlue<T1, T2, eglue_type> &) [with eT=double]" function template "const arma::Mat<double> &arma::Mat<eT>::fixed<fixed_n_rows, fixed_n_cols>::operator=(const arma::eGlue<T1, T2, eglue_type> &) [with eT=double, fixed_n_rows=50U, fixed_n_cols=9U]" operand types are: arma::Mat<double>::fixed<50U, 9U> = const arma::eGlue<arma::Op<arma::Mat<double>, arma::op_repmat>, arma::Mat<double>::fixed<50U, 9U>, arma::eglue_minus> ash1=repmat(alpha,1,9)-beta; ^ compilation aborted for bugarma.cpp (code 2)
I've reproduced the issue and will submit to dev team to fix. I do not have a workaround as of now, I'll look into details and maybe ask developer whether a workaround can be provided.
Shenghong
Hello Shenghong,
Sorry to bump this thread, but did you by any chance got a workaround or patch so far? I'm stuck on using g++, and missing some speed improvements from icpc.
Daniel
Try to use the member function .eval(), which in words of the API Reference "explicitly forces the evaluation of a delayed expression and outputs a matrix" (armadillo 3.2 or greater). For example,
#include <armadillo> //using armadillo5.000.2 using namespace std; using namespace arma; int main() { complex<double> c = 2.0; cx_mat33 A = randu<cx_mat>(3,3); A = (A*c).eval(); return 0; }
I tested this code with icpc and g++-4.8. On the other hand, icpc will fail if I use A = A*c instead, where I get the following error:
icpc program.cc -o program -larmadillo program.cc(8): error: more than one operator "=" matches these operands: function template "const arma::Mat<arma::cx_double> &arma::Mat<eT>::operator=(const arma::eOp<T1, eop_type> &) [with eT=arma::cx_double]" function template "const arma::Mat<arma::cx_double> &arma::Mat<eT>::fixed<fixed_n_rows, fixed_n_cols>::operator=(const arma::eOp<T1, eop_type> &) [with eT=arma::cx_double, fixed_n_rows=3U, fixed_n_cols=3U]" operand types are: arma::cx_mat33 = const arma::eOp<arma::cx_mat33, arma::eop_scalar_times> A = (A*c); ^
Hope this helps,
Roberto Navarro.
Hello Roberto,
Thanks a bunch for that solution. It will save me until a regular fix will be found.
Daniel
Hello all,
Conrad Sanderson, one of the authors of armadillo, wrote a workaround (thanks a lot :-) in the new release (5.100.2) of the library. This avoids using the eval trick, which apparently has some potential performance issues.
Daniel
Hi Max, Daniel,
This issue is fixed in latest 2015 U3 release. Please upgrade your compiler and let me know if it is not fixed for you.
$ source /opt/intel/composer_xe_2015.3.187/bin/compilervars.sh intel64
$ icc temp.cpp -I armadillo-4.650.2/include
$ ./a.out
Shenghong
Thanks Shenghong,
Unfortunately my license seems having expired and I cannot upgrade. My institution mainframe set-up is out of my control but I'll ask if they plan to upgrade soon. Otherwise I'll investigate on buying a local license.
Daniel
