I intermittently encounter problems while debugging a large, mixed language application (Fortran, C/C++). I am using version 9.1 of the Intel C/C++ and Fortran compiler and MS Visual Studio 2005.
The problem that I encounter is that I am unable to examine the value of variables sometimes. The message that is generated is:
CXX0069: Error: variable needs stack frame
Sometimes this occurs when I step into a new block in C/C++, e.g.
.... code where I am able to examine variables...
.... when I step into this block, variables that I was able to examine outside of this code block are no longer "visible" to the debugger. This does NOT appear to be a problem with name conflicts, where a variable declared in the block masks an identically named variable from outside the block.
Has anyone else encountered this problem and does anyone know how to get around it?
I don't know if this is relevant or not, but Main is written in C++.
Dale
