I installed intel c++ compiler 9.0 integrated with eclipse IDE on kubuntu (5.10) as the instruction of package. now i can compile and run the code in bash. However, when i use eclipse i get error in eclipse console view ("/bin/sh: icc: command not found").
i did not have such a problem in SUSE. should i set any variable environment in eclipse?
Hadian
Hadian
In the bin subdirectory of your compiler installation, you should find a script for launching eclipse called iccec. If you use that script to start eclipse, it will set up the compiler environment for you.
Hope that helps...Bill
Thank you Bill. your suggestion works.
Now i can use eclipse in Ubuntu.
