Intel® C++ Compiler
Problem with Windows Kernel Driver
Andreas_S_
Writing kernel drivers for 64 bit Windows with Intel compilers is quite convenient, because of the inline assembler (Microsoft is not supporting inline assembling for 64 Bit, and the intrinsics are very scrappy).
But alas there seems to be a problem with the access to the jump-tables (used by switch/case) in rdata The only work-around until now I could figure out is to completely switch off the use of jump-tables: /Qopt-jump-tables:never.
Does anybody know a better solution?
(using Intel 11.1.065, VS2008SP1 & Win server 2008R2).
regards as
Lingfeng_C_Intel
Thanks As,
Could you tell me which kind of problem you met? any test case I can use to reproduce it?
Wise
levicki
Valued Contributor I
If I understand correctly, jump tables get stored in a section which is not marked as executable? Or is your problem something else?
