I have an executable compiled with icpc v12.0.2. When I load it intointo gdb and try to open any source file, the following message appears:
Dwarf Error: Cannot find DIE at 0x7639ed8 from DIE at 0x771ca3d [in module ...]
Same code built using same makefile but with icpc v11.1.059works withgdb without problems.
Any idea why it's happening and how it can be fixed?
Dmitri.
Dmitri.
Could you try the latest Intel C++ compiler 12.0 update 4? If you still face the issue then request you to share test case to reproduce the issue and investigate.
