Intel® C++ Compiler
Problem with #include <climits>
mnaydin
I hava problems compiling C++ programs which includes climits. The operating system is Debian Linux (64-bit), icc version is 12.0.4, gcc version is 4.3.2. The following test program does not compile with icpc (but it compiles with g++):
#include
#include
int main()
std::cout << INT_MAX << "\\n";
return 0;
The error message:
/usr/include/limits.h(125): catastrophic error: cannot open source file "limits.h"
# include_next
compilation aborted for test.cpp (code 4)
Interestingly, when I use #include , instead of #include , the test program compiles with icpc and runs correctly.
bernaske
i have compile your sample with icpc 12.0.4.20110427 version under openSUSE 12.1 M1 64 Bit linux
without any problems, i think its a OS or environment setting problem,
on openSUSE 12.1 the Intel ICC/ICPC Version 12.0.4.20110427 works without troubles with your sample
regards
Franz
Om_S_Intel
I can also compiler the code in FC11 using icc 12.0.4.191. Could you please try compiling with gcc?
Om
Scheibe__Patrick
same problem here: Ubuntu 10.04,g++ (Ubuntu 4.4.3-4ubuntu5) 4.4.3, icpc12.0.4 20110427
Compiling the small sample program with icpc gives the same error message. Compiling it with g++ works fine.
When I compile the sample with
icpc -Wall -I /opt/intel/composerxe/include
it works but on my real program I get then the warnings
/opt/intel/composerxe/include/math.h(19): warning #561: nonstandard preprocessing directive
# include_next /* utilize and expand sys header */
/opt/intel/composerxe/include/math.h(19): warning #561: nonstandard preprocessing directive # include_next /* utilize and expand sys header */
Any ideas?
Cheers
Patrick
Scheibe__Patrick
Hi again,
it seems the problem is the compilervars_arch.sh script. When you look at the other scripts which were made for
tbb, ipp, mkl than you see that they set the CPATH to the corresponding include directory. The include path of the
compiler is not set. When I add
if [ -z "${CPATH}" ]; then
CPATH="${INSTALL_DIR}/compiler/include"; export CPATH
else
CPATH="${INSTALL_DIR}/compiler/include:$CPATH"; export CPATH
fi
if [ -z "${CPATH}" ]; then CPATH="${INSTALL_DIR}/compiler/include"; export CPATHelse CPATH="${INSTALL_DIR}/compiler/include:$CPATH"; export CPATH
fi
to the
/opt/intel/composerxe-2011.4.191/pkg_bin/compilervars_arch.sh
script it seems everything is running fine.
Cheers
Patrick
