I think I might have found a bug in the Intel Compiler XE2014 Version 14.0.1.139 (Both linux and windows). I've attached a simple piece of code which reproduces the problem in the hope that it can be fixed. The code compiles fine under linux using clang 3.3 and gcc 4.8.1.
I get essentially the following two error messages from Intel:
[bash] constexprMember.cpp(21): error: expression must have a constant value
static constexpr std::array<bool, LENGTH> boolArray{{ VALUES_ARG...}};
constexprMember.cpp(24): error: expression must have a constant value
static constexpr std::array<bool, LENGTH> boolArray = helper<0>::template getValues<arrayHelper>::boolArray;[/bash]
Raffael
Hi Raffael,
I've reproduce the problem you reported, and entered it to our problem-tracking database. Thank you for your report.
icc 14.0 update 3 contains a fix for this issue. FYI.
