Hi guys.
I am using icpc version 16.0.0 (gcc version 5.0.0 compatibility), there seems to be an issue using std::ref and std::vector, i am trying to initalize a bunch of threads with reference for std::vector with the code:
void doTheMath(const int startIndex, const int endIndex, std::vector<int>& matrix, const int givenSeed) { int seed = 0; for (int i = startIndex; i < endIndex; ++i) { seed = givenSeed + i; seed = VAL_A * seed + VAL_B; matrix = seed % 100; } } void Cpp11::randmat(int nrows, int ncols, int s) { int totalMatrixSize = nrows * ncols; int numThreads = 4; int operationsByThread = totalMatrixSize / numThreads; std::vector<int> matrix(totalMatrixSize); std::vector<std::thread> threadsList; for (int i = 0; i < numThreads; ++i) { threadsList.emplace_back(std::thread(doTheMath, operationsByThread * i, operationsByThread * (i + 1), std::ref(matrix), s)); } for ( auto &t : threadsList ) { t.join(); } }
To compile i'm using:
icpc cpp11.cpp randmat.cpp -std=c++11 -pthread
And i'm getting this error:
/usr/include/c++/5/functional(78): error: class "std::vector<int, std::allocator<int>>" has no member "result_type" { typedef typename _Functor::result_type result_type; }; ^ detected during: instantiation of class "std::_Maybe_get_result_type<_Functor, void> [with _Functor=std::vector<int, std::allocator<int>>]" at line 86 instantiation of class "std::_Weak_result_type_impl<_Functor> [with _Functor=std::vector<int, std::allocator<int>>]" at line 184 instantiation of class "std::_Weak_result_type<_Functor> [with _Functor=std::vector<int, std::allocator<int>>]" at line 264 instantiation of class "std::_Reference_wrapper_base_impl<true, true, _Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 283 instantiation of class "std::_Reference_wrapper_base<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 399 instantiation of class "std::reference_wrapper<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 36 of "randmat.cpp" /usr/include/c++/5/functional(266): error: class "std::vector<int, std::allocator<int>>" has no member "argument_type" typedef typename _Tp::argument_type argument_type; ^ detected during: instantiation of class "std::_Reference_wrapper_base_impl<true, true, _Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 283 instantiation of class "std::_Reference_wrapper_base<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 399 instantiation of class "std::reference_wrapper<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 36 of "randmat.cpp" /usr/include/c++/5/functional(267): error: class "std::vector<int, std::allocator<int>>" has no member "first_argument_type" typedef typename _Tp::first_argument_type first_argument_type; ^ detected during: instantiation of class "std::_Reference_wrapper_base_impl<true, true, _Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 283 instantiation of class "std::_Reference_wrapper_base<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 399 instantiation of class "std::reference_wrapper<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 36 of "randmat.cpp" /usr/include/c++/5/functional(268): error: class "std::vector<int, std::allocator<int>>" has no member "second_argument_type" typedef typename _Tp::second_argument_type second_argument_type; ^ detected during: instantiation of class "std::_Reference_wrapper_base_impl<true, true, _Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 283 instantiation of class "std::_Reference_wrapper_base<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 399 instantiation of class "std::reference_wrapper<_Tp> [with _Tp=std::vector<int, std::allocator<int>>]" at line 36 of "randmat.cpp"
I atached the source and the preprocessor file.
Strangely in g++ there is no problem. Someone can help me? Thanks in advance!
Can you compile with -P to generate the preprocessed .i file and attach to this issue? Thx.
_Kittur
Yes.
Pablo, yes this looks like a bug and I'll file with the developers. BTW, can you can you also attach the source files as well? Thanks.
_Kittur
I attached both files in my first post. Keep me advised if possible and thanks for the help.
Great, thanks Pablo I'll get back to you.
_Kittur
Hi Pablo,
Done with investigation and this is a bug in the compiler for now and is being worked on for a fix. I'll keep you updated as soon as the release with the fix is out. The bug is due to the recent versions of the GNU headers which use a new c++11 rule (related to SFINAE) to make the right call be chosen and a fix is being implemented.
There's no general workaround for this problem (beyond using a version of GNU older than 5.0) and so you'll have to wait for the compiler release with the fix and I'll keep you updated accordingly when it's out.
For this particular code example you attached, you can add the declaration below, somewhere before the definition of Cpp11::randmat() in your test case: (See attached newrandmat.cpp file with this code change):
namespace std {
template<typename T>
struct _Reference_wrapper_base<std::vector<T>> {};
Again, appreciate your patience and I'll keep you updated as soon as the release with the fix is out, thanks
_Kittur
I am suffering from the same issue. Running latest ICC:
icpc (ICC) 16.0.1 20151021
gcc (SUSE Linux) 5.3.1 20151207 [gcc-5-branch revision 231355]
I get the same error messages, e.g.:
/usr/include/c++/5/functional(78): error: class "lambda []()->std::unique_ptr<Object, std::default_delete<Object>>" has no member "result_type"
I'd like to inquire about fix release date and possible temporary workaround.
Thank you
Hi Shlomi,
As mentioned in my earlier response, there's no general workaround for this problem (beyond using a version of GNU older than 5.0) and so you'll have to wait for the compiler release with the fix and I'll keep you updated accordingly when it's out. Appreciate your patience till then.
Kittur
The fixed in update 2, which I just installed. Happy coincidence.
Thank you
Yes, you're correct! Thanks for the confirmation :-)
@Pablo - this is fixed in the latest update 2 release that's out, thanks. As always, appreciate your patience through this...
_Kittur
