During installation of the Composer XE (namely I_ccompxe_intel64_2011.1.107)
the system cheked the license number (passed OK) and further the "prerequisits"
and claimed the g++ is missing. The command
# yum install gcc
yields the responce: gcc (version 4.1.1. or so) is already installed.
It seems all gcc-related packages are installed.
What can I do now to install the Composer?
Your help is greatly appreciated!
# yum install gcc
Hi Alex,
Please try the following command to install g++.
# yum install gcc-c++
This article might be helpful to you: http://software.intel.com/en-us/articles/using-intelr-compilers-for-linux-under-fedora/
Feilong
Feilong
Hi
The compiler Intel version 64 bit require IA32 library package
also verify that you have an libstd++ GNU already installed with libtool binutils etc ...
Read link given by Feilong H. if other packages are absent (lib compat etc ...)
