Intel® C++ Compiler
7956 Discussions
Problems with std::bind when using gcc 4.8.0 with icc 14.0.1.
peter_b_
Hi there,
I have problems compiling the following code where a public method foo2 of class Bar uses std::bind on another such method foo. I am using icc 14.0.1 20131008 and gcc 4.8.0
//compile with: icc main.cpp -std=c++11
#include <vector>
#include <iostream>
#include <functional>
class Bar {
public:
  void foo(double x, double y) {
      std::cout << x << std::endl;
      std::cout << y << std::endl;
  void foo2(double x) {
    using namespace std::placeholders;
    auto function = std::bind(&Bar::foo, this, x, _1);
    function(0);
int main(int argc, char **argv) {
  Bar bar;
  bar.foo2(1);
The error message reads:
 error: no instance of overloaded function "std::_Bind<_Functor (_Bound_args...)>::operator() [with _Functor=std::_Mem_fn<void (Bar::*)(double, double)>, _Bound_args=<Bar *, double, std::_Placeholder<1>>]" matches the argument list
            argument types are: (int)
            object type is: std::_Bind<std::_Mem_fn<void (Bar::*)(double, double)> (Bar *, double, std::_Placeholder<1>)>
      function(0);
I am not having this problem using the same Intel Compiler but with gcc 4.7.2 instead
Thanks for your help!
gcc 4.7.2 20130108, icc 14.0.1 20131008, boost 1_49
peter_b_
sorry for the bad formatting and please ignore the last two lines
