Hi, I essentially need the profile guided optimizations, because without them the executables are huge and slower. I have ICC 2016 and I also tried ICC 2018, in both cases same results - while the normal build produces working executables (sames as all other compilers - MSVC and CLANG), profile guided generation executables crash (after compiling for hours and producing over 200MB executable, both 32bit and 64bit Windows).
Command line for compiler:
icl.exe /D "MNOPARAMETERCHECK" /D "MELDAPRODUCTIONAUDIOPLUGINKERNEL" /D "MELDAPRODUCTIONAUDIOPLUGINKERNELV11" /D "MVERSION=\"12.00a\"" /D "MVERSIONINT=0xC0000" /D "NDEBUG" /D "MLIBRARYDLL" /D "MPROJECTNAME=MeldaProductionAudioPluginKernelV11" /D "MPROJECTNAMESTRING=\"MeldaProductionAudioPluginKernelV11\"" /D "MENABLETBBxxx" /D "MINTELIPP_8" /D "MINTELIPP" /D "MUNICODE" /D "MENABLEDIRECTSOUND" /D "MENABLEASIO" /D "_SECURE_SCL=0" /D "_WINDOWS" /D "UNICODE" /D "_MBCS" /D "WIN32" /GR- /bigobj /Qrestrict /arch:SSE2 /Qprof-gen /Qprof-dir c:\PROFGEN\MeldaProductionAudioPluginKernelV11 /MT /TP /Fd"!temp/ReleaseReleaseIntelcompiler0/MeldaProductionAudioPluginKernelV11/vc70.pdb" /D_USRDLL /D_WINDLL /D_WINDOWS /DWIN32 /MP /Fo"!temp/ReleaseReleaseIntelcompiler0/MeldaProductionAudioPluginKernelV11/KERNEL.obj" /FR"!temp/ReleaseReleaseIntelcompiler0/MeldaProductionAudioPluginKernelV11/" /I "D:/programming/mlibrary" /I "D:/Programming/MDrummer/MDrummer" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\ia32" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\icc" /I "D:/programming/mlibrary/library/" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/include" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/include" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/tbb/include" /D_MBCS /Wp64 /c /W3 /Gm- /Qstd=c++14 /Zc:forScope /nologo /Gd /GF /EHsc /fp:fast /GS- /Qdiag-disable:1292 /Qvc14 /Qm32 /O1 /Os /vec- MDrummer/KERNEL.cpp
Command line for linker:
icl.exe kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib comctl32.lib wsock32.lib winmm.lib msimg32.lib psapi.lib opengl32.lib Glu32.lib freetype.lib zlib.lib libpng.lib libtiff.lib libjpeg.lib giflib.lib bzip2.lib libflac.lib vstsdk3.lib aax.lib asio.lib libmad.lib fcnn.lib ippsmt.lib ippvmmt.lib ippcoremt.lib ippimt.lib /link /MP /OUT:"D:/Programming/MDrummer/BINEffects/binkernel/MeldaProductionAudioPluginKernelV11.dll" /INCREMENTAL:NO /RELEASE /MACHINE:X86 /SUBSYSTEM:WINDOWS,5.01 /DYNAMICBASE /DLL /IMPLIB:"D:/Programming/MDrummer/!temp/ReleaseReleaseIntelcompiler0/MeldaProductionAudioPluginKernelV11.lib" /LIBPATH:"D:/programming/mlibrary/library" /LIBPATH:"D:/Programming/MDrummer" /LIBPATH:"D:/Programming/MDrummer/!temp/ReleaseReleaseIntelcompiler0" /LIBPATH:"D:/Programming/MDrummer/BINEffects/bin" /LIBPATH:"C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/lib/ia32" /LIBPATH:"C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/tbb/lib/ia32/vc12" /LIBPATH:"C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\lib\ia32" /nologo /MANIFEST:NO /Gy /Qoption,link,/OPT:REF /OPT:REF /OPT:ICF
In case it would help, this is where it crashes (access violation):
1CBA6915 movq xmm1,mmword ptr ds:[246684ACh] 1CBA691D movq xmm0,mmword ptr ds:[2067DD60h] 1CBA6925 paddq xmm1,xmm0 1CBA6929 movq mmword ptr ds:[246684ACh],xmm1 1CBA6931 mov dword ptr [ebp],20h 1CBA6938 cmp dword ptr ds:[24008288h],0 1CBA693F je 1CBA755D 1CBA6945 movq xmm1,mmword ptr ds:[240082B8h] 1CBA694D movq xmm0,mmword ptr ds:[2067DD60h] 1CBA6955 paddq xmm1,xmm0 1CBA6959 movq mmword ptr ds:[240082B8h],xmm1 1CBA6961 cmp dword ptr ds:[240084C4h],0 1CBA6968 je 1CBA7544 1CBA696E push dword ptr ds:[11990004h] 1CBA6974 push dword ptr ds:[11990000h] 1CBA697A push 5 1CBA697C movq xmm1,mmword ptr ds:[240084E4h] 1CBA6984 movq xmm0,mmword ptr ds:[2067DD60h] 1CBA698C paddq xmm1,xmm0 1CBA6990 push 0DEECE66Dh 1CBA6995 movq mmword ptr ds:[240084E4h],xmm1 1CBA699D call 203DC4E0 1CBA69A2 add eax,0Bh 1CBA69A5 movq xmm1,mmword ptr ds:[240082A8h] 1CBA69AD adc edx,0 1CBA69B0 xor ebx,ebx 1CBA69B2 movq xmm0,mmword ptr ds:[2067DD60h] 1CBA69BA movzx edi,dx 1CBA69BD paddq xmm1,xmm0 >>>> 1CBA69C1 mov dword ptr ds:[11990000h],eax 1CBA69C6 mov dword ptr ds:[11990004h],edi 1CBA69CC shr eax,10h 1CBA69CF shl edi,10h 1CBA69D2 or edi,eax 1CBA69D4 movq mmword ptr ds:[240082A8h],xmm1 1CBA69DC cmp dword ptr ds:[24008620h],0 1CBA69E3 je 1CBA752B 1CBA69E9 movq xmm0,mmword ptr ds:[24008640h] 1CBA69F1 movq xmm1,mmword ptr ds:[2067DD60h] 1CBA69F9 movq xmm2,mmword ptr ds:[240082B0h] 1CBA6A01 paddq xmm0,xmm1 1CBA6A05 paddq xmm2,xmm1 1CBA6A09 movq xmm3,mmword ptr ds:[2067DEC0h] 1CBA6A11 mov dword ptr [esp],2400822Ch 1CBA6A18 mov dword ptr [esp+4],7 1CBA6A20 movq mmword ptr ds:[24008640h],xmm0 1CBA6A28 movq mmword ptr ds:[240082B0h],xmm2 1CBA6A30 movq mmword ptr [esp+8],xmm3 1CBA6A36 call 203BAC60 1CBA6A3B push ebx 1CBA6A3C movq xmm5,mmword ptr ds:[24668484h] 1CBA6A44 movq xmm4,mmword ptr ds:[2067DD60h] 1CBA6A4C push 0FFFFFFFFh 1CBA6A4E paddq xmm5,xmm4 1CBA6A52 push ebx 1CBA6A53 push edi
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Does it crash if you compiled at default (without /Qprof-gen /Qprof-dir)? Can you debug further by compile with /Zi? or possible provide us with a test case to investigate?
Viet
Hi Viet,
it works fine when compiled without profgen. It also works fine with all other compilers. Interestingly the 2016 ICC produces crashing code on x86, but works fine with x64. It's all really really unpredictable... I'm afraid I cannot provide a test code, it's a gigantic project and I have no idea where it crashes. I'll try the /Zi option when possible, but since it blocks the build machine for like 3-4 hours, it may take a while...
Ok, so I tried to use the /Zi compilation, but for some reason no PDB files have been created. I got dirty, so here's the full command line. I'm using Visual Studio express 2017. First I initialize environment like this:
"C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Auxiliary\Build\vcvarsall.bat" x86 "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\bin\compilervars.bat" x86
Interesting thing then happens when I run the intel compiler, this message:
icl: remark #10421: The IA-32 target wrapper binary 'icl' is deprecated. Please use the compiler startup scripts or the proper Intel(R) 64 compiler binary with the '-Qm32' option to target the intended architecture
Not exactly sure what is causing this. Anyways the compiler is executed like this (removed gazillion include paths etc):
icl.exe /GR- /bigobj /Qrestrict /arch:SSE2 /Qprof-gen /Qprof-dir c:\PROFGEN\MeldaProductionAudioPluginKernelV11 /MT /Zi /TP /Fd"!temp/xxx/vc70.pdb" /MP /Fo"xxx.obj" /FR"xxx" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\ia32" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include" /I "C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\include\icc" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/include" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/include" /I "C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/tbb/include" /D_MBCS /Wp64 /c /W3 /Gm- /Qstd=c++14 /Zc:forScope /nologo /Gd /GF /EHsc /fp:fast /GS- /Qdiag-disable:1292 /Qvc14 /Qm32 /Od xxx.cpp
As you can see it's a debug build, unfortunately the result is the same as release with all the optimizations - it crashes nearly immediately. Also note that it's a DLL.
This error comes up :
warning #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could not be found on your path. This is usually a configuration error. Compilation will continue using /Z7 instead of /Zi, but expect a similar error when you link your program.
That's probably why no PDB gets created. But mspdb140.dll is in the location, where MSVC compiler is, so I assume it should be in the PATH (unless the intel batch messed it up of course).
Now the linker:
icl.exe xxx.obj kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib comctl32.lib wsock32.lib winmm.lib msimg32.lib psapi.lib opengl32.lib Glu32.lib freetype.lib zlib.lib libpng.lib libtiff.lib libjpeg.lib giflib.lib bzip2.lib libflac.lib vstsdk3.lib aax.lib asio.lib libmad.lib fcnn.lib ippsmt.lib ippvmmt.lib ippcoremt.lib ippimt.lib /link /MP /OUT:"D:/xxx.dll" /INCREMENTAL:NO /RELEASE /MACHINE:X86 /SUBSYSTEM:WINDOWS,5.01 /DYNAMICBASE /DLL /IMPLIB:"D:/xxx.lib" /PDB:"D:/xxx.pdb" /LIBPATH:"C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/ipp/lib/ia32" /LIBPATH:"C:/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/tbb/lib/ia32/vc12" /LIBPATH:"C:/Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\compiler\lib\ia32" /nologo /MANIFEST:NO /Gy /Qoption,link,/OPT:REF
Result: it nearly immediately crashes... Normal builds work fine. What now?
A little update: I changed the environment setup to:
"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018\windows\bin\compilervars.bat" ia32 vs2017
Now it doesn't show any errors during compilation except for:
icl: warning #10210: problem with Microsoft compilation of 'D:/programming/xxx.cpp'
Anyways it creates the vc70.pdb during compilation (see the previous post), but linker doesn't create the resulting PDB and MSVC says it hasn't been compiled with debug symbols...
I managed to generate the PDB via MSVC directly and here is where it crashes:
class MRandBase { MUINT64 State; public: MFORCEINLINE MUINT64 GetValue() { static const MUINT64 mul = MUINT64(0xDEECE66DUL) | (MUINT64(0x5) << 32); static const MUINT64 add = (MUINT64)0xB; static const MUINT64 mod = MUINT64(1) << 48; State = (State * mul + add) % mod; <<<<<<<<<<<<< return State >> 16; }; };
Access violation, State variable is fine, so it cannot access the local static consts, which is just a nonsense... It works fine with normal release of course. Crashes just with profgen. I think we can agree that there is a bug in the compiler.
And the debug state...
1026ED2F mov dword ptr [mod],0 1026ED36 mov dword ptr [ebp-14h],10000h State = (State * mul + add) % mod; 1026ED3D mov eax,dword ptr [this] 1026ED40 mov edx,dword ptr [eax] 1026ED42 mov eax,dword ptr [eax+4] 1026ED45 add esp,0FFFFFFF0h 1026ED48 mov dword ptr [esp+0Ch],5 1026ED50 mov dword ptr [esp+8],0DEECE66Dh 1026ED58 mov dword ptr [esp+4],eax 1026ED5C mov dword ptr [esp],edx 1026ED5F call _allmul (1787DB20h) 1026ED64 add eax,0Bh 1026ED67 adc edx,0 1026ED6A add esp,0FFFFFFF0h 1026ED6D mov dword ptr [esp+0Ch],10000h 1026ED75 mov dword ptr [esp+8],0 1026ED7D mov dword ptr [esp+4],edx 1026ED81 mov dword ptr [esp],eax 1026ED84 call _aullrem (1787DB60h) 1026ED89 mov ecx,dword ptr [this] 1026ED8C mov dword ptr [ecx],eax <<<<<<<<<<<<<<< 1026ED8E mov dword ptr [ecx+4],edx return State >> 16; 1026ED91 mov eax,dword ptr [this] 1026ED94 mov edx,dword ptr [eax] 1026ED96 mov eax,dword ptr [eax+4] 1026ED99 mov dword ptr [ebp-8],eax
Btw. the State variable is normally accessible and writable in debugger, so it's probably the intel's profiling thing... definitely a bug...
