Hi all,
I havean applicationbuilt using2 shared libraries. The associated *.dyn files related to these2 shared libraries are generated in2 separate directories, when application is executed. When I create a pgopti.dpi file after putting all *.dyn files related to2 shared librariesin a single directory and then create a coverage report out of it, it gives me coverage information about source files present in only one shared library. So I lose all the coverage information for otherlibrary.
If I createpgopti.dpi files related toeach library, and merge pgopti.dpi files with profmerge -a, and then create coverage report then also I end up with coverage information about same single library.
If I create pgopti.dpi file from *.dyn files related to other library and generate coverage report then I could get coverage information forother library correctly.
Please let me know, is this a known issue with profmerge tool, and how could I resolve this.
Thanks in advance.
Sunil
--mark
I did not mention it earlier, I am using profmerge on SuSE Linux (64bit) and not on Windows.
Sunil/
Pleasenote thatthe primary information that drives the code coverage report comes from the pgopti.spi file. If you are targeting your shared objects to different directories using the prof-dir option with prof-gen:srcpos, then you are also producing 2 different pgopti.spi files. As a result, even if all the .dyn data is merged into a single .dpi file, the information contained in the coverage report is only going to be about the files/routines that are listed in whichever pgopti.spi that gets loaded. So, I would check whether this is the scenario that you have different pgopti.spi files for the different shared objects.
Please also note that there is notcurrently a way to merge pgopti.spi files.
--mark
