Intel® C++ Compiler
Project fails to compile after 2015 Update 1
dnesteruk
I've just applied Update 1 of the 2015 toolset and now cannot even build projects. I'm getting the following message:
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Platforms\x64\PlatformToolsets\Intel C++ Compiler XE 15.0\Toolset.targets(150,5): error : Could not expand ICInstallDir variable. Platform toolset may be set to an invalid version number.
dnesteruk
Trying to repair, but the installer says:
Repair can't be done because no available sources were found
TimP
My experience has been that I had to remove all 2015 versions and install intel compilers from scratch both under win7 and 8.1
Marián__VooDooMan__M
New Contributor II
I had similar issue when I installed ICC 15.0 first release, and again after installing Update 1.
It broke "c:\program files (x86)\msbuild\" directory.
I managed this to do daily backup twice a day, and restored it from backup. Old version works just fine. I can't guarantee it will work correctly in your environment, but I will attach 7z-ipped MSBuild directory for you to give it a try, but don't forget to backup old one, i.e. rename original to "MSBuild.bak" first.
My environment is for MSVC 2013 Ultimate, Win 8.1 Pro x64. also, I have ICC 14.0 Update 6 and ICC 15.0 Update 1 installed, but if your system is missing ICC 14.0.x, as rules in my setup (attached file) for it are included, it will cause no harm.
It's worth to give it a try. See attach "Program_Files_(x86)_MSBuild.7z".
PS: please, give me a feedback.
dnesteruk
I really don't think that reinstalling everything is a viable option for me and I think that's using those files that you've posted will be last resort option I am wondering therefore if somebody at Intel it's actually aware of the situation and whether they have any advice for how to remedy this since it looks like I'm not the only one who's actually experiencing this problem
New Contributor II
I saw bug report in this forum few weeks ago, but I am unable to find it in inbox, but it was unanswered by Intel at that moment. Just try my workaround, and let me know whether it is working well, because @Tim's suggestion to reinstall Windows is very costly...
dnesteruk
     I didn't think I can do this safely. The problem is that this directory probably contains all the customizations that I've added from various packages such as CUDA and if I were to replace this directory with your files I could lose the support of some of the project types that I previously had.
So I'm hoping that somebody from Intel would pay attention to this post and maybe suggest a workaround that doesn't involve me altering my system in any significant way.
JenniferJ
can you build a new helloworld project with Intel C++ successfully?
is it possible to attach the .vcxproj file? you can use send author a msg to send the file directly.
Jennifer
New Contributor II
From my experience, you only need to replace directory content and sub-dirs in the file I attached "c:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\" <- that is for MSVC 2013.
It should not interfere/kill CUDA, or maybe if so, you will only need to reinstall CUDA.
Please, give it a try and let me know.
dnesteruk
Jennifer
I have just sent you a file. I am unable to build a fresh project, too.
New Contributor II
But I recommend to backup old MSBuild, replace it from attached file, and then reinstall CUDA; or even better, first uninstall CUDA, replace MSBuild, and install CUDA again.
dnesteruk
CUDA is only one of a number of packages that I use. The suggestion to reinstall them all is unrealistic.
New Contributor II
Okay, I have sent working MSBuild, and when you don't want to give it a chance, just to only try it, then I cannot give you more help. So your only chance is to reinstall Windows, if you refuse *just and only* to give it a try. I'm sorry that I wanted helped you, as you don't read me.
New Contributor II
I am sorry to be so rude, but you even have not give it a chance...
JenniferJ
Thanks for helping out!
Now the Intel Parallel Studio XE 2015 Update 1 Professional Edition is available from the download center now. please download it and try again.
Jennifer
Stuart_M
Update 1 removed my Parallel Studio compilers instead of updating them! WTF Intel! QA testing?
dnesteruk
Yes, I think that's exactly what happened - instead of upgrading the compilers, Update 1 actually removes them. That's why I couldn't find any of those IPS-specific directories anymore.
New Contributor II
I needed reinstalled my Win 8.1, and my file with MSBuild as attachment in this thread doesn't work any more. I get same error as original poster wrote.
Could please someone attach C:\program files (x86)\MSbuild (from x64 platform) zipped or 7-zipped of working MSVC 2013 (V120) Update 4 and ICC 15.0 Update 1 ?
TIA!
New Contributor II
I resolved problem in my CMD script by using:
set Path=c:\Program Files (x86)\MSBuild\12.0\Bin\;%Path%
instead of non-working:
set Path=c:\Program Files (x86)\MSBuild\12.0\Bin\amd64\;%Path%
This works for x64 target as well.
New Contributor II
Sorry, false alarm.
After installing the update, I get same error as @dnesteruk reported.
The solution is to uninstall compiler, and install one before last version.
