Intel® C++ Compiler
7782 Discussions
Pure virtual call behaviour difference between VS and ICC
Netanel_K_Intel
The following code works if compiled with VS but fails with ICC:
class A {
public:
	  virtual void F() = 0;
class B : public A {
public:
class C : public B  {
public:
	  virtual void B::F() override {}
int _tmain(int argc, _TCHAR* argv[])
	  C c;
	  A* a = &c;
	  a->F();
	  return 0;
Obviously, removing the 2nd F declaration in B or the "B::" part from F’s definition in C will remove the issue.
What I was wondering is whether this is a bug or just a quirk and of which of the compilers?
Netanel_K_Intel
Just found that g++ won't compile:
error: cannot define member function ‘B::F’ within ‘C’ virtual void B::F() override {}A
And Intel compiler will indeed issue a warning, but not in the default warning level:
warning #1125: function "A::F()" is hidden by "C::F" -- virtual function override intended?
Visual studio compiles clean.
thanks,
