(On Windows 7 Pro x64 with PS XE 2013 and MS VS 2012)
I am trying to resolve an issue when compiling for MIC native where the include path is not set up correctly. Using one of the sample native applications, which compile "icl -Qmic ...". When compiling without -Qmic the sample program compiles (yes this is posted under a different message), however this is something new. In an attempt to resolve the issue I wanted to add -QdM to display the macros. -QdM is recognized as a valid option when compiling without -Qmic, with -Qmic the compiler complains about invalid option (along with stdio.h not being found).
FYI I also tried SET GXX_INCLUDE=%INCLUDE% as a hack test (as I do not have GCC installed).
Is GCC required to be installed (on Windows) in order to perform native (-Qmic) compilations using ICL?
Jim Dempsey
Jim, can you try -Qoffload-option,mic,compiler,"options" -- see this link, http://software.intel.com/en-us/node/459712
There's a gcc included in the MPSS stack.
That sets default options, I want to see what default INCLUDE path is.
(minimal) gcc did not come with MPSS 3.1 for Windows. That is likely the issue.
Installed Cygwin
Set GXX_INCLUDE=C:\cygwin64\usr\include
Then compile, stdio.h found, stddef.h not found.
Set GXX_INCLUDE=C:\cygwin64\usr\include;C:\cygwin64\lib\x86_64-mingw32\4.8.1\include
(where stddef.h located)
Still stddef.h not found.
Transposed paths about ";"
stdio.h not found
Apparently multiple paths cannot be specified.
I also set CPATH to the above, same issue.
Any help would be appreciated.
Jim Dempsey
I see you've posted also in the MIC forum, that's a place for these questions.
This link shows how to set up your software for Windows hosted compilations, including MPSS installation: http://software.intel.com/en-us/articles/intel-xeon-phi-coprocessor-developers-quick-start-guide
