Intel® C++ Compiler
7873 Discussions
/Qdiag-enable:openmp broken in Composer XE 12.0.2?
AndrewC
New Contributor III
/Qdiag-enable:openmp seems to be broken in Composer XE 12.0.2.154 (Windows 64-bit)
I can't seem to get this to work. If I switch compilers back to 11.1.067 I get the expected output
e.g
(col. 5) remark: OpenMP DEFINED LOOP WAS PARALLELIZED
TimP
Black Belt
The compiler diagnostic you quote is enabled by /Qopenmp along with /Qopenmp-report or /Qopt-report (for either version).
AndrewC
New Contributor III
BTW, has anyone noticed, or is it just me, that subscribing to a thread does not seem to generate an e-mail as expected.
JenniferJ
Probably there is an issue with the forum. I'm posting again to see if you will get the notification.
Could you respond once you get the email notification? Otherwise if I didn't hear from you by next Monday, it means you didn't get the email notification.
Thanks for letting us know.
Jennifer
