Using /Qipo breaks compilation with /SAFESEH or /Qsafeseh. If I use /Qip then everything compiles fine and the resulting executable has SEH table.
I don't see something relevant in the documentation so I come to the conclusion that this is somehow broken or it's by design like this. Can someone shed some light on this?
I'm using Intel Parallel Composer 12 update 4.
Thanks in advance.
Thanks in advance.
It would be nice if you can share a sample code so that we can investigate and narrow down the issue.
It would be nice if you can attach the test case to this thread.
The test case is in the link I posted. Anyway, attached is the source code.
Things to try:
* Run "build\Notepad2_icl12.sln" and you'll see that the executable will have the problem I described.
* Change /qipo to /qip and it will work as it should.
* Specify /SAFESEH in the linker, so that it's forced to generate SEH table, with /qipo and you'll get compilation errors.
Error 23 error LNK2026: module unsafe for SAFESEH image. C:\Users\user\Desktop\notepad2-mod\src\WPO.obj Notepad2
Error 24 error LNK1281: Unable to generate SAFESEH image. C:\Users\user\Desktop\notepad2-mod\bin\ICL12\Release_x86\Notepad2.exe Notepad2
All of the above apply to the "Release|Win32" config of course.
Note that Microsoft's compilers works fine.
Things to try:
This seems an issue with compiler. I have submitted a report to Intel Compiler development team on this. I will update the thread when I have more information.
Thanks! It was baffling me for quite some time...
May I also suggest that the default location for the WPOObject file is set to IntDir? Because if it's not set the WPO object file gets generated every time even if nothing has changed and it can take a while for large projects.
One last thing I'd like to see in the documentation is something like this. It helps a lot to see which compiler switches are in effect with each optimization option enabled. If it's already there, sorry for that.
It would be nice if we have a smaller testcase.
Sorry, not possible. Isn't that something the Intel developers should take care of when reviewing this issue? I don't see why I have to provide a smaller test case when this happens every time regardless of the code.
I found this small program and decided to try ICC. The problem is present there, so here is your smaller testcase. Open FeetToMeters.sln and compile Release|Win32.
But like I said, the code doesn't matter, the problem always happens with /Qipo.
Thanks for helping with small testcase.
The issue is fixed in the latest Intel C++ Composer XE 2011.
Topic Options
