Intel® C++ Compiler
Qoption in icc.cfg file
Przemysław_O_
I have to use an compiler command line option in Visual Studio Intel C++ Project:
/Qoption,cpp,--pch_control=268435456
due the compile error: Intel C++ 16.0 Error : Unable to Obtain mapped memory (see pch_diag.txt)
I have this problem only on one machine, and it would be good to enable it on machine level.
Can I use this /Qoption in icc.cfg? Is there a help/faq for this configuration file?
Best regards
Przemek
Melanie_B_Intel
Yes you can put the Qoption into the configuration file
There's documentation here: https://software.intel.com/en-us/node/522780
Note that on Linux there are 2 different configuration files, one for C compilations and one for C++ compilations
--Melanie
