Intel® C++ Compiler
_Quad type math errors
handsomeforest
I downloaded and installed the latest intel oneAPI (w_BaseKit_p_2022.1.0.116_offline).  I have the following code in Visual Studio 2022.
int main() {
_Quad n = 23.1416Q;
int m = (int)__log10q(n); // there is a bug in Intel 2021 compiler. need to do cast here
int mm = __log10q(n);
printf("m = %d, mm = %d", m, mm);
if (mm != m) {
printf("!!!!!!!!!!!!!!!!!!!!!!!!!!!!n = %g, m = %d, mm = %d\n", (double)n, m, mm);
return m;
However, I got the following wrong errors:
debug x64: m = 2, mm = 2
release x64: m = 2, mm = 2
debug x86: m = -4859, mm = -4859
release x86: m = -4939, mm = -4939
I believe the correct result should be m = 1, mm = 1.
Attached here is the test project.  Can you try to reproduce the problem on your end?  Thanks
Junlin Xu
NoorjahanSk_Intel
We are able to reproduce your issue with icx compiler(2022.1) at our end.
We are working on your issue. We will get back to you soon.
Meanwhile, could you please try using icl classic compiler? As we are able to get the expected results for both x64, x86 in both debug and release mode.
Please find the below screenshot(x86 Debug and x64 Release) for more details with the classic compiler(19.2) in Visual Studio 2022 with oneAPI 2022.1
Thanks & Regards,
Noorjahan.
handsomeforest
Thank you for the confirmation, Noorjahan.
I do not see Intel C++ 19.2 on my visual studio 2022.  I only see the option of Intel C++ 16.0 classic which I purchased in 2016.  When I do use Intel C++ 16.0, I got build errors as shown here.  How can I get Intel C++ 19.2 option appear on Visual Studio 2022?  Is it free?
Junlin Xu
NoorjahanSk_Intel
>> How can I get Intel C++ 19.2 option appear on Visual Studio 2022?..
Could you please confirm whether you have installed oneAPI HPC toolkit in your system?
If not, please download and install oneAPI HPC Toolkit as the Intel classic compiler comes with this toolkit.
>>Is it free?
Yes, it is free. You can download oneAPI HPC Toolkit from the below link
https://www.intel.com/content/www/us/en/developer/tools/oneapi/hpc-toolkit-download.html
Please do let us know if you face any issues.
Thanks & Regards,
Noorjahan.
handsomeforest
Noorjahan:
I can confirm that Intel C++ 19.2 works for me.  Please do let me know if when the bug is fixed in Intel C++ 2022.
Junlin Xu
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
Devorah_H_Intel
This issue was fixed in the latest oneAPI release.
handsomeforest
Hello @Devorah_H_Intel , I tried the latest 2024 oneAPI release on my Windows 10 with Visual Studio 2022 v17.8.2.  The 64-bit build is fixed while the 32-bit build is not.  Attached is my test app again.  The following is the summary of the results:
_Quad n = 23.1416Q;
int m = (int)__log10q(n); // bug in intel c++ 2024 compiler for 32-bit build?
// yields in 32-bit debug: m = -4935, mm = -4935
// yields in 32-bit release: m = -4939, mm = -4939
// yields in 64-bit debug: m = 1, mm = 1
I just wanted to make sure that Intel C++ 2024 compiler can compile 32-bit target application.  Thanks.
Devorah_H_Intel
_Quad n = 23.1416Q;
warning : 32 bit tools (PreferredToolArchitecture=x86) are not supported in Intel C++ Compiler toolset. 64 bit tools (PreferredToolArchitecture=x64) are used in this build.
32bit  builds are not supported with icx
same for ifx
handsomeforest
@Devorah_H_Intel , are you certain that we cannot build 32-bit target using Intel C++ compiler 2024 64-bit tools?  The warning "32 bit tools (PreferredToolArchitecture=x86) are not supported in Intel C++ Compiler toolset. 64 bit tools (PreferredToolArchitecture=x64) are used in this build." is about the build tools, not build target.  I can use Visual C++ 2022 which is a 64-bit build tools to build 32-bit applications.
Alex_Y_Intel
Hi @handsomeforest, thanks for your question.
@Devorah_H_Intel meant that Intel oneAPI compiler no longer compiles/generates binary to be executed on 32-bit machine, and indeed this is the case. Please also be aware that oneAPI base toolkit 2024.0 already has icc/icl (Intel classic compiler for Linux and Windows) removed.
handsomeforest
