Intel® C++ Compiler
7876 Discussions
Quadruple precision in a C/C++ programme
jpelaez
Hi
I am trying to use qudruple precision on a C/C++ programme using the extended option of the Compiler but I get problems. The following code
#include
#include
#include
void get_half_pi(long double);
int main(int argc, char *argv[])
_Quad Pi=3.14159265358979323846q, zz;
char buf[50];
get_half_pi(Pi);
printf("\\n C++ version:");
printf("\\n Pi = %23.20Lf %032llx\\n", (long double)Pi, Pi);
fflush(stdout);
printf("\\n");
zz = __atanq(1.0q);
return 0;
give me a problem in the sentence zz = __atanq(1.0q). I am using the compiler flag:
-Qoption,cpp,--extended_float_type
The compiler is able to compile and link the programme and it produce an .exe file. However, in the execution the programme experiences a crash in that sentence because __atanq is unknown. Please, would anybody give me a solution to this problem?
I am working in a Windows 7 machine.
Thanks a lot.
jpelaez
Well:
I discovered how to avoid the problem. It was very easy: I had to declare the function
_Quad __atanq(_Quad x)
and the programme runs !!!
These are the goods news.
Now  the bad news: there is no way to know what is stored in the variable
zz = __atanq(1.0q);
I tried to obtain the value of zz with _gcvt  but it does not work. I obtained the same result than in double precision.
Please, would anybody tell me how to obtain a real quadruple precison number?
Thanks again.
jpelaez
TimP:
thanks a lot for your answer. Unfortunately the printf (and alike functions) are not able to manage the _Quad type introduced by Intel in the C/C++ compiler. You can convert the _Quad to a double, but in such a case you loss the information that is inside the _Quad, becasue the diference between the
Regarding to write the routine that convert a _Quad number in a string of chars, I have no idea of the characteristics of the _Quad type and is impossible to me to do it. I though that perhaps Intel has some tool dan can be used.
Finally, how to disply the _Quad number in hexadecimal format? I do not know if it is possible.
Thanks again. Jesus
jimdempseyatthecove
Black Belt
Have you tried adding _Quad type to the << operator list in std::cout (this is in ostream)?
Jim Dempsey
TimP
Black Belt
In order to display hex, you might store into a union including a quad and an int or long long int array.  Surely at least printf() can handle the hex display of the ints.
jpelaez
Jim:
thanks a lot for your suggestion. I did not try it because the programme where we need quadruple precision is enterely written in C. However, I will follow your idea in order to see if it works. I will tell you. Thanks again. Jesus
jpelaez
Tim:
I will try your suggestion. I will tell you if I have success. Thanks. Jesus
jimdempseyatthecove
Black Belt
...the programme where we need quadruple precision is enterely written in C.
The problem is you do not have a %qf (quad float) format capability. This will require you to create your own convert to string function:
    char* Quad2string(char* fmt, _Quad x);
Where fmt is "%[flags][width][.precision]qtype"
and type is e, E, f, g, G, a, A
IOW same as what you might guess a proper format would be expressed using "q" as _Quad type modifier. Or select "ll" lower case el, twice  for twice long. Note, "%llf" in printf is typically "double" not "long long".
  printf("Result = %s\n", Quad2string("%25.3qf", Result); // or "%25.3llf"
I leave it up to you to either write the function or search the internet for code someone else has written.
Look at:
http://sourceforge.net/p/qpfloat/mercurial/ci/393210c0cefbf1e445bb4ab598db4de984699e0e/tree/
This project is for emulating quad precision, and it contains a convert to string. This may have some useful code to read/use.
Jim Dempsey
