Intel® C++ Compiler
Question about Intel compiler(icx)
Daniil5441
I use icx compiler recently. I wonder if icx uses polly to optimize code?
SeshaP_Intel
Thank you for your patience.
Currently, there is no intention to support Polly in icx(Intel® oneAPI DPC++/C++ Compiler).
We are committed to improving icx's performance. Based on the results from the development team icx is showing much better results than clang+polly.
Could you please confirm whether we can close this thread from our end?
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We are working on this issue internally. We will get back to you soon.
Thanks and Regards,
SeshaP_Intel
Could you please try the Loop Optimizations and Vectorizer in icx(Intel® oneAPI DPC++/C++ Compiler) which have good product quality in terms of performance, stability, and compile time.
Please refer to the below link for more details.
https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2023-0/overview.html
Please let us know if you have tried and found that there are any applications in which Polly has shown better performance with the Intel LLVM compiler.
Thanks and Regards,
Daniil5441
HI,
Thank you for answering me.
I have one problem. I don`t know how to use polly with Intel LLVM Compiler, but I compared Clang+polly with Intel LLVM Compiler and had got that Clang with polly creates slower code. But I am also interested in trying polly with Intel Compiler, so I will know exactly that polly works worse than native Intel LLVM Compiler.
SeshaP_Intel
Could you please share the source code, the steps you followed, and the results from Clang+Polly and Intel LLVM Compiler?
Could you please let us know how you are stating that Polly creates slower code with Clang?
Thanks and Regards,
Daniil5441
Firstly, I compiled "benchmark_decode.cpp" with "qoir.h" with Intel LLVM Compiler.
Secondly, in my code I have small benchmark that counts execution time of one decoding function called "qoir_decode" and prints "Decode time: some time" and I used Vtune to see what function takes most of the time.
Thidly, I repeat first and second steps but with Clang+Polly.
For Intel LLVM Compiler I used flags:"-fuse-ld=lld -fast -flto=thin -xHost".
For Clang+Polly I used flags:"-Ofast -march=native -flto=thin -mllvm -polly".
I had the next result:
For Intel LLVM Compiler: 72 milliseconds stable
For Clang+Polly: 79 milliseconds stable
In Vtune I got that the critical function "qoir_private_swizzle_bgrp__rgbn"  with Intel LLVM Compiler takes more time to complete than the same part code compiled with Clang+Polly that takes twice less time to complete, but other parts of code takes more time. So I had that in general Intel LLVM Compiler generates faster code.
For correct using you need type in console: "benchmark_decode path/to/file".
Qoir image that I used for benchmarking, all sources and vtune profiling files are in attachments.
I have a question: Is there a chance to use polly with Intel LLVM Compiler?
SeshaP_Intel
Thanks and Regards,
SeshaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
