Community
cancel
Showing results for
Search instead for
Did you mean:
Question about thread number on 2CPU
Hi, I need some help....
I've developed a application to work on image.
There are so many object to inspect, So we are testing on workstation platform with 2CPU(Xeon E5).
I have 32 Thread(each CPU has 8Core and 16 Thread), But Openmp Works only Half Side.
I set '32' thread using omp_set_thread_num function, but It works only 16thread.
What should i do to solve this problem?
The O/S : Windows Server 2008
Ram : 16GB
Black Belt
I think you mean omp_set_num_threads but you haven't given enough detail. Intel openmp defaults to 2 threads per core when hyperthreading is enabled. If you call an mkl function that function defaults to 1 thread per core on Xeon as that gives best performance.
