CPU:Intel Core i7-2600
memory:4G
OS:Windows XP sp3
Compiler:Intel(R) C++ Compiler XE 12.1.7.371 [IA-32]
I use the code in vec_samples in "Tutorial: Auto-vectorization".
(path: ..\Composer XE 2011 SP1\Samples\en_US\C++\vec_samples)
when command line switch is: /O2 /QaxSSE3 /Qstd=c99, the vectorized code is SSE2.
Then I change align(16) to align(32) and add some "#pragma" directives.
when command line switch is /QxAVX, the vectorized code is still SSE2!!
So my question is "how to generate the AVX codr by auto-vectorization"?
_declspec(align(32)) FTYPE a[ROW][COLWIDTH];
_declspec(align(32)) FTYPE b[ROW];
_declspec(align(32)) FTYPE x[COLWIDTH];
void matvec(int size1, int size2, FTYPE a[][size2], FTYPE b[], FTYPE x[])
int i, j;
for (i = 0; i < size1; i++) {
b = 0;
#pragma simd
#pragma vector aligned
for (j = 0;j < size2; j++) {
b += a
It's difficult to believe the assertion that /QxAVX produces SSE2. It's possible that AVX-128 might be used to handle odd values of size2; the align(32) couldn't do anything useful unless size2 were known to correspond to a multiple of 32 bytes.
QaxSSE3 of course will produce SSE2, as you are asking for SSE2 and also a separate SSE3 path in the case where the compiler sees value, but in this case there is no value in SSE3 unless FTYPE is a supported complex data type.
If you choose to use #pragma simd for sum reduction, you must specify the reduction in accordance with the model.
FTYPE bsum = 0;
#pragma simd reduction(+: bsum)
bsum += a
b = bsum;
I myself don't see the appeal of this; if you want an Intel extension, there are Cilk reducers; if not, there is inner_product(). The only point of the #pragma simd reduction is to over-ride your compiler option, in case you set an option such as -fp:source which turns off reduction vectorization.
