Intel® C++ Compiler
R Orphaned Processes
David_W_1
I've noticed strange behaviour with launching parallel processes in R that only appears when R is built with icc. The spawned parallel processes are not killed when the main process ends.
Example code is as follows:
library(foreach)
library(doMC)
registerDoMC(cores=4)
d <- rep(1,16)
t <- foreach(i=1:4, .combine=c) %dopar% {
    s <- foreach(1:4, .combine=c) %do% 1*1
identical(t, d)
Here we see the 4 spawned process are orphaned at the completion of the script.
build$ Rscript HungRProcs.R
Loading required package: iterators
Loading required package: parallel
[1] TRUE
build$ ps -elf | grep R
F S UID        PID  PPID  C PRI  NI ADDR SZ WCHAN  STIME TTY          TIME CMD
1 S root      1427     2  0  80   0 -     0 worker May15 ?        00:00:00 [SCIF INTR 0]
0 S build    19173 26999  0  80   0 - 35960 poll_s 12:27 pts/1    00:00:00 vim RStats-3.0.3-dw.spec
1 S walling  24425     1  1  80   0 - 51468 hrtime 13:11 pts/5    00:00:00 /home1/00157/walling/software/R-3.1.0/bin/exec/R --slave --no-restore --file=HungRProcs.R --args
1 S walling  24426     1  1  80   0 - 51468 hrtime 13:11 pts/5    00:00:00 /home1/00157/walling/software/R-3.1.0/bin/exec/R --slave --no-restore --file=HungRProcs.R --args
1 S walling  24427     1  1  80   0 - 51468 hrtime 13:11 pts/5    00:00:00 /home1/00157/walling/software/R-3.1.0/bin/exec/R --slave --no-restore --file=HungRProcs.R --args
1 S walling  24428     1  1  80   0 - 51468 hrtime 13:11 pts/5    00:00:00 /home1/00157/walling/software/R-3.1.0/bin/exec/R --slave --no-restore --file=HungRProcs.R --args
0 R walling  24430 21882  0  80   0 - 27561 -      13:11 pts/5    00:00:00 ps -elf
0 S walling  24431 21882  0  80   0 - 25814 pipe_w 13:11 pts/5    00:00:00 grep R
The configure used for the icc build is as follows:
build$ ./configure --prefix=/home1/00157/walling/software/R-3.1.0 CC=icc F77=ifort FC=ifort CXX=icpc
If built with gcc, the spawned processes are terminated when the main process completes. The configure used for the gcc build is as follows:
build$ ./configure --prefix=/home1/00157/walling/software/R-3.1.0 CC=gcc F77=gfortran FC=gfortran CXX=gcc
I have run tests against both R 3.0.3 and 3.1.0, different parallel backends via doMC, doSNOW and straight mclapply. I've also tested with multiple versions of the GNU compiler and Intel compiler and on both Centos 5.10 and 6.5. All tests cases have resulted in the same behaviour.
Any ideas why the compiler would affect proper termination of spawned sub-processes?
Note: This question was asked on Stackoverflow, but has not yet received any replies(http://stackoverflow.com/questions/23919216/hung-parallel-processes-in-r-icc-vs-gcc).  I thought I would try here as it seems specific to the intel compiler.
KitturGanesh
Hi David,
I downloaded R and tried to install and had installation issues. So, what I did was to take the same program example you have and compiled and ran with icc  as a standalone program. I didn't see any spawned processes and the program did exit gracefully. BTW, I'll follow up with you further on this in the issue you filed in Premier, fyi.
Kittur
jimdempseyatthecove
My guess is gcc is calling a thread termination/final/exit function for main when main returns and icc is not.
Place a break point at the return from main (or at close } of main). When you reach there, set the debug view to disassembly, then single step out of main. Do this for gcc first keeping notes of the call stack and any routines called on the way. If this provides you with a clue as to the difference, then you may be able to concoct a fix yourself. (In addition to explaining what you found out.)
Jim Dempsey
KitturGanesh
Hi David,
This is strange and have not seen such behavior and needs investigation and will get back to you on this.
_Kittur
KitturGanesh
Hi David,
Kittur
KitturGanesh
David, may be there could be an issue when configuring and building R with icc which needs to be investigated further. I'll follow up with you in Premier on this issue, fyi.
_Kittur
KitturGanesh
Hi David,
Yes, I built R successfully (had to install the iterators, the foreach and the doMC packages etc) and I could reproduce the issue and do see spawned processes left over with ICC. I've filed the issue with our developers and will get back to you as soon as I have an update, thanks much.
_Kittur
David_W_1
A work around for this bug is detailed here.
https://bugs.r-project.org/bugzilla3/show_bug.cgi?id=17152
