Intel® C++ Compiler
RDTSCP Question
Oniel_K_Intel
Platform environment:
i5-661 on Intel TomCove board DH55TC, Win 7 Ultimate (x32), VS2008 w/SP1, Intel C++ Compiler version 11.0.066.
Question is trying to execute RDTSCP instruction. RDTSC works. Using Intel C++ in MS VS2008 IDE.
Error is:- "error: unkown opcode "RDTSCP" -- __asm"
When I switch to using Use Visual C++ RDTSCP code compiles and executes. Problem is I want to use Intel C++ Compiler.
code snippet:-
__int64 StartCPUCycle(void)
__int64 cyclesStart;
__asm
{// retrieve the clock-cycles for the start value:
RDTSC // works
//RDTSCP //does not work
mov DWORD PTR cyclesStart, eax
mov DWORD PTR [cyclesStart + 4], edx
return cyclesStart;
any thoughts, solutions???
Oniel...
Feilong_H_Intel
Hi Oniel,
Were you using which version of Visual Studio? I tried VS2008, which doesn't recognize RDTSCP either.
As a workaround, you may use the intrinsic __rdtscp. See http://msdn.microsoft.com/en-us/library/bb385235.aspx
Feilong
Oniel_K_Intel
Hi Feilong,
Thanks for the link.
I am using VS2008 with SP1. I got RDTSCP to compile using VS2008 C++.
My question was more directed to why Intel C++ would not compile RDTSCP. After further analysis,
ia32intrin.h header file for Intel compiler does not support RDTSCP.
Oniel...
TimP
Should be present in ICL . You may need an upgrade to support instructions which weren't present at the time your ICL was built.
